Leaf springs
Springfield Illinois
Kevin
My 78 half ton has these springs. the one on the ground I believe is for a square but i couldnt tell you what for, just potentially a half ton
That first picture looks like what my rear leaf springs are.
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
So then 2 leafs for a small block and 3 leafs for a big block i take it.
Or diesel, which was originally the case for me. I have a set of different springs, but I’ve been lagging on getting them installed.
89GMCJimmy
ivan
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
nabeshin
functioning lunatic
Cozad, Nebraska
Grae
I had always thought that my front springs were sagging. Reverse arch puts the suspension travel only a few inches to the bottom out bumpers. Maybe a slight 2" lift is in my future.
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
I’m glad I bought mine when I did, though I haven’t installed them yet. Looks like the price frickin doubled. Mine were about $1500 for all four springs.
Now I’m contemplating coils, but I don’t think I’ll like how non-stock it’d look.
This kit is the whole **** and sharoo. Shocks included and these are the Deaver replica multi leaf super sexy flexy top of the line springs.
ORD will sell you whatever you want, not just the whole kit.
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
Mine are the multi leaf “ORD custom” springs, but not the whole kit. They asked me about a hundred questions before ordering them—there were definitely compromises made between payload capacity and flex. I went more flexy. Already had the grease able shackles, u bolts and shocks...still might need brake lines, but only asked for 2” lift. Their website used to state no ubolt flip kit for the rear on one tons because the spring plate could hit the frame.
As stated, still a lot to think about before slapping it all on and waiting for the 33” tires to wear some so I can justify new 35s.
89GMCJimmy
ivan
On the front of the truck, there is a bumpstop right above the front axle. Measure from the top of the axle tube (not the spring or spring plate, but the axle tube) to the bottom of the metal bumpstop bracket. A stock truck is about 8-1/2”
89GMCJimmy
ivan
thatgermanguy
