K10 non removable tunnel
mavtricks71
az
mike
So my 86 K10 has a non removable transmission tunnel....has anybody seen this ? I thought they were all removable.
yevgenievich
Place
Name
Year
Model
Size
After they went square headlights they are all non removable
CSFJ
I seem to recall hearing that the bolt in tunnel was still there for a year or two ofter the body change in '81, but the one piece floor is what you'll find in most of the eighties vintage trucks.
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
Yep, that's normal. I wish they would have left it the old way. Swapping a C-cab onto a K-frame or vice versa would be a weld-free operation.
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
x2. I'm about to cut the perfectly rust free floor out of my 88' and modify a 78' bolt in hump to work, for my NV4500 swap. My life would be much easier if I could just bolt it in...le sigh.
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
It sounds daring going into it, but I'll bet it'll be worth it in the long term.
mavtricks71
az
mike
Thanks for replies.... glad to know it's normal
It wasn't quite that early, they were still bolt-in as late as '83. That could have been the last year though.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
How much clearance do you need? You might get away with a small body lift... like 1". If you will do any serious 4wheeling, don;t go more than 1" or the cab will eventually begin to wiggle and squirm around. Plus it looks looks dork town.
87scotty
Central il
Andrew
V20
5.7 for now
Hey now when I bought my truck it came with a 3inch body and does just fine 4 wheel in serious lol
87scotty
Central il
Andrew
V20
5.7 for now
This is the definition of twerking haha
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
My truck is a 2WD, so I'll be avoiding body lifts like the plague. Besides, I already started cutting, lol! A very basic, rough cut just to get started, but still...it's a hole and all, hah.
mavtricks71
az
mike
Dang what exactly is the cutting for, are going to put in AOD or something? just curious :burnout:
Big Chip
Michigan
Kevin
C35
My 79 is non removable.
CSFJ
Did the 2wd trucks get a removable tunnel, or was that only the 4x4s and manual trans trucks?
jlyon1006
