Swims350
- Jul 30, 2010
- Logan WV
- Chris
- K10
- none
OK guys I've fought steering issues with this k10 ever since I've got it. It acted like it had alot of play in it before, I adjusted the gear box a lil bit, changed to a cavalier steering wheel, seemed to help a lil. I then changed power steering pumps, keep squalling, tightened belt good got better. Well I had alot more issues after the rc 6 inch, I installed the raised arm, I bought both drag link ends and adjuster sleeve new, set them same legnth as old, installed and had like no turning, so I adjusted it/lengthen and had good turning on stands. We never drove it more then the driveway from spot to spot, and it always seemed to be alot of steering wheel turning and not much tire turning. Well yesterday she hit the road again, and it's all over the place, you have to over steer inside and get under steer outside on the ground. What I mean is tons of steering wheels turns equals very little tires turning. Ok ow get this, on stands, I fie it up turn the wheels lock to lock, and the steering stops are almost touching the axle, when on the ground, lock to lock, they are 1/2 inch or more from hitting. I try adjusting the drag link and by that of course I mean from the pitman arm to the raised steering arm on the axle. It's like to get full turn on one side I need it adjusted as long as possible, but yet other side it has to be as short as possible. I cannot get full turn lock to lock on the axle with the weight of the truck on the tires, I removed my steering dampers to make sure it wasn't them. Now when I do adjust the drag link I am turning the wheel in the truck, engine on, until it stops, shut it off and lock the ign. When I adjust it either way, and try to fire and turn the other way, wheel is locked and key is very hard to pop over, and when it does wheel turns on it's own like 1/2 turn or more.
My frame was broke before, and fixed, and I put the plate on the frame and welded it up good along with their washers welded to the inside. I watched it and there was no flex at the frame or box. I also when I first got the truck had to tighten the pitman arm nut as moving the steering wheel you could watch it go up and down. It was the pitman arm, tightening it fixed that, wasn't a sector shaft movement.
How screwed am I? I'm thinking it's the gear box.??
I also had to change the lower steering column bearing.
