1978 k10 Steering Column issues
Steelerguy
Pittsburgh North
Scott
Two Issues going on:
1. The Key Spins without any tension. - No Power / Start
2. I can move the gear shifter from park without the key.
The steering wheel does lock with key removed.
I just replaced the Ignition Drum and that didn't fix anything.
I can see with the steering wheel off that the Ignition selection arm is moving. Obviously from the Key to towards me. What it does below the key is Why I am here.
What mechanism locks the Gear Selector?
Any way to Bypass or manually engage the Ignition switch to get it in the garage?
Steelerguy
Pittsburgh North
Scott
Stand Down, I did use the search and just now seeing it could be or is the Colum Selector gear /rack. Now to find a how to video!
F1r3truck
