no slack
- Feb 26, 2013
- Georgia
- Antonio
- c10
- 5.7 350 TBI
Ok sorry to anyone following othe treads of mind had some computer tech problems and could not get online.
This is the issues I'm having as of today
1. The steering column is in bad shape. The ignition works find with key and the gear shift is find. The turn signal is on the left sid but is not locked tight (broken or not screwed I'm not sure) the wiper switch on the turn signal work find so I'm sure the wires or connected. The person before me put a nail in the column on the right near the gear shift that contorls the turn signal. The steering wheel it self is after market its locked in but at the has a lot of play in it. What I would like to no about this is can theis be restored if so how and what's needed?
2. Front in restoration . I notice after driving the front tires where balling out bad both on the inside. I got advice of different things tire rod end control arms everything. I have replaced tire end rods iner and outer both sides and edle arm. Problem just got worst and now do to new parts alignments is way off. What I would like to no is what's else there to do other than ball joints ?? And how to do a ball joint job. I have been told to replace the control arms makes it little easy but the bottom one takes some work. What work does the bottom one take and how do I replace the control arms. Thanks and I'm sorry if its hard to understand tried to make it simple
