ive never rebuilt, is this rebuildable?
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
looks like bearing caps are bolted to oil pan holes for the feet. Not sure if the piston holes line up or need to be drilled. You would need to secure the pistons so they wouldnt flop over and the glass slide off.
Mine already has the pistons and rods out. Only thing left in it is the cooked crank, timing chain n gears and t. chain cover and some "pieces" of the cam
You think so? I looked at that and my initial thought was "how are the piston heads set - and kept - perfectly parallel to the plane of the glass"?
But, picture the glass being layed down on the pistons - with the pistons floating on the pins. The weight of the glass will push down the high sides of the pistons and the low sides will rise up till they are flush with the glass. And that's where they will stay - until the glass is removed.
74propu
florida
austin
c10s/b c10 s/b c10l/b
5.3 / ?/454 tbi
A few years back I had a DZ 302 complete from carb to oil pan under plexiglass setting on a 4 wheeled stand used it for a tv stand . It was in the house for 2 years till I put it in a 73 c10.
Camar068
Kentucky
10 yrs Air Force
You think so? I looked at that and my initial thought was "how are the piston heads kept parallel to the plane of the glass"?
They might be, would make setting the glass on easier tho.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Please tell me it had the staggered carbs..........
74propu
florida
austin
5.3 / ?/454 tbi
No sorry it had a duel port offy tunnel ram and 2 500 cfm holleys
74 Shortbed
Those intakes are cool looking..
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
Enlighten me... whats a DZ302?
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
First gen Z28 Camaro engine advertised at 290 hp but was optioned with that sexy intake set up in the trunk. Trans Am series had a CID rule of 302 CID. Which spawned the DZ for Chevy the Boss 302 for Ford and I guess the 304 for AMC.
74propu
florida
austin
5.3 / ?/454 tbi
Yea advertised at 290 hp But in real life they put out 390 hp with the stock intake and 425 with the sexy intake and tuned twins on top . In 68 and 69 it was a 327 block with a 283 crank in 69 it was given its own crank and block and the DZ stamp in the block #.
CSFJ
I had heard those engines were screamers. Never seen hp figures until you posted those. I had also heard they were known for snapping cranks. Was that both versions, or 1 more than the other?
fussfeld
east coast
j
c-10
4.3 v-6 262CID
i think if the damage is that low on the cylinder wall it can be saved. But it would probably be cheaper/easier to just get a crate 350 than to rebuild irregardless?
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
Thats what i thought to but im not interested in rebuilding it im just curious so i know because im trying to sell it over scrap it but itll probly get trashed as well as both of my th350s
fussfeld
east coast
j
c-10
4.3 v-6 262CID
So what is core value for a 350 block? $75?
All my used blocks are sitting in my garage, because i can't bear to part with them. Even though one is not practically rebuildable with a cracked cylinder wall....
jlyon1006
