Is it harmful to drive in "2" for long periods of time?
Big Chip
Michigan
Kevin
C35
On the Chevette deal, they race those at Waterford Hills in, where else, Waterford! Lots of rollovers last time I was there.
4.3 with 2.56's and 35's... While the gearing may work out in 2nd on the highway, the truck WILL NOT like leaving from a stop. Getting rolling would be incredibly slow and you will likely overheat the trans in the process.
I will suggest a crazy idea though. Install a th350 with a shorter output shaft to accept an np205 transfer case. Then use low range for towing. I'm sure it will still require taller rear tires to get the rpm right, but at least the truck will have the balls to get moving.
Oh ****! I had forgotten about this thread.
A ****** year later and still no pics.
Pretty sure I seen this fella on another forum asking about transmission trouble on the same rig. Could be somebody else though.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
Still works in 2 wd...
Big Chip
Michigan
Kevin
C35
Stewart G Griffin, aka fussfeld, is now trying to diagnose his TH350 slipping in all 3 gears if anyone is interested. My suggestion to him would be to buy a Toyota and be done with the problems a 40 year old vehicle presents. He doesn’t take advice so he won’t do that though.
350 w/203
Chevy Legend
