idahovette
- Aug 7, 2016
- Weiser Idaho
- Perry
- K20-K10
@OldBlueDually fingers crossed for you!!!!
Do the above before you invest further time and money or you might spend a lot of time and money chasing your tail.I would pull the lifters on those loose cylinders and make sure that they aren't flattening the cam. They get concave on the bottom.
My $.02 on "If I had wiped cam lobes, or wiped lifters don't you think you would see a crap-ton of metal filings in the oil filter? I don't see anything beyond typical wear/break-in stuff." If you had seen a crap-ton of metal then that would be positive something eat itself, but and for example we had a 77 C20 in here last year. We installed a stock built remaned unit from what we use to consider a good source, broke the cam in properly and ran high zinc oil. It came back after a short time with what appeared to be a misfire and some lifter noise. Sure enough the #7 intake lifter was concaved. indicating the cam was flattened, or in the process of doing so. The oil did not look really any worse than normal break in but we did not descent the filter. On the other had we had an AMC 360 in a couple years ago with multiple lobes gone. This engine did have obvious metal in the oil.To everyone questioning why I did not prime the engine, see the below PDF, step #9;
Everything I did is exactly to what they stated. Remember, I oiled & assembly lubed the living sh!t out of everything, I was not concerned about not having enough oil. When this 455 started you would've thought there was a problem for how much smoke it produced because of my over-oiling (if there is such a thing) of everything.
So, back to the noise issue, and oil filter findings, and what I now see which may have contributed. Things that did not help: Felpro head gaskets being thicker, wear on the rocker arms, wear on the rocker pivots. What I saw in the oil filter: wear/break-in materials, some fine aluminum (thinking from rocker pivots going to new extremes and creating a wear pattern in rockers), nothing seen in oil filter that blew my mind, or warranted an engine yank out and back to the stand.
At this point, with now seeing I have no bent pushrods, and the rockers/pivots should have NEVER been used to begin with due to the wear of them (my own fault), and without seeing metal all over in the oil filter I am still debating whether to take off the intake or not. If I had wiped cam lobes, or wiped lifters don't you think you would see a crap-ton of metal filings in the oil filter? I don't see anything beyond typical wear/break-in stuff.
After I decide what to do: I am going to change the oil, install a new filter, install adjustable rockers (thanks @Matt69olds as they arrived today!!), figure out what pushrod length I need, then order new hardened pushrods, and then set rockers properly and lock them down, then fire this beast back up.
I interpret step #9 of the PDF you referenced a little differently. I think it's saying do not prime the engine before setting the valve lash (which is apparently not applicable to your Olds engine's factory style rockers). The lifters shouldn't be fully "pumped up" for initial valve adjustments. I don't think it's referencing anything else, but it isn't very clear either.To everyone questioning why I did not prime the engine, see the below PDF, step #9
Oddly, I couldn't find any mention of priming the engine before breaking in the cam. There were plenty of details regarding lubrication, engine RPM, and duration of the cam break-in procedure, but no mention of engine priming. Bizarre...
I guess it is what it is at this point. If I were you, I'd be very tempted to run it and periodically check on the rockers and pushrods. That's just my style though, and everyone has their own. Rob is right, it's certainly not a fun place to be in.
