Scott91370
- Apr 2, 2018
- Burleson, Tx
- Scott
- Sierra1500
@Scott91370,... when was the last time you selected "vent" on your heater a/c control slider and that kick panel vent didn't move? If so, then you need a vacuum pot for that door as well.
Never, the truck hasn't run or been together enough since I bought it to try the controls. But both do move when I apply vacuum to them so the diaphragms should be in good shap.
@Scott91370 I found this alternate part number GM 15606307 and ebay search. This has the later vacuum pod with a bigger nipple, but you can install yours or run an adapter fitting. Action says 5 are available.
https://www.ebay.com/itm/1981-87-Ch...door-C-K-81-87-C-10-K-10-C20-K5-/192889515818
I appreciate that! And that's a good price too! It must have been newer since I searched, there were two at the time; one looked like mine and the other looked to be painted all black. Wasn't sure on either.
I went ahead and cut the rest of the plastic 'hinge' part and put two 2" stainless (hoping they don't rust) hinges on it and it works great now. Thanks for all the input!
