Came up to the shop Sunday afternoon to work on this some more. Decided to knock out the bodylift since it's pretty simple and I only had a few hours. First, I measured where I was starting out, height-wise. 38" up front, 37 5/8" in the back (don't jump on me for Carolina squat, the front will settle after I drive it some lol).
Then removed the front bumper, super easy, it's just 6 bolts. Remove the grille, 2 bolts on the top of each frame rail and then one underneath on either side for the little side support bars
Took all the driver's side body and core support bolts out, loosened the other side. Took the bolt out of the steering shaft so it could slide, popped the brake lines out of their holders and some of the wiring to make sure it had slack and then started to lift the driver's side.
Found the e-brake cable was gonna be too tight so I trimmed the tab off the mount (Idk what the purpose is for the tab anyway, I've always knocked it flat for tire clearance in the past).
