Huck's daily - 2005 Z71 crewcab
So last night I decided to shimmy the carrier over to the pass side a touch more to tighten up my backlash. Remember spec is .006-.010 and I was at .010. Took a .005 shim and moved it to the driver's side. That got me to .004. Phooey
Did some more math...
And ended up at .007!!
So then I decided to go ahead and do final assembly. Pressed on the pinion bearing. That took all the ass this little press had lol. I hate presses, they're sketchy
Put the crush sleeve on, threw the pinion in with a fresh seal and started to crush the crush sleeve. Spec here is 14-19in lbs of rotational drag. I was doing my best to just sneak up on it and kept getting 10-12in lbs time after time after time. The last push, I went just a touch more and suddenly had 20in lbs! o_O o_O I was so mad lol. Spun the pinion a bunch and kept remeasuring. On my coworker's split beam I borrowed, there's only 3 hashes in between the 10s, so it's kinda hard to judge anything under 20. I figured I was 18-20ish. Talked to Spencer and he pointed out that you need to add 2-3in lbs for the pinion seal. That was not mentioned anywhere in my kit or anything I read/saw online, so he's a life saver. 20 puts me right in the middle of spec
So last thing, I ran one more pattern to be sure and it came out great so I'm calling that good. Just gotta go grab some axle seals at the parts store and I can fill her up and be done with the rear
All that mathemagicianal stuff on the big chief tablet makes me infinitely glad it ain't me doing this job :eek:
legopnuematic
Licensed Junk Dealer
MO
Spencer
With your press woes, some extreme pressure grease goes a long way on making press fits smooth, mitigates galling, etc. something like this:
Doesn’t hurt if things feel really tight to run a little Emory cloth on the journals, just enough to make sure there are no dingleberries that might give trouble.
Being a machinist, I have the luxury of being able to make sleeves to be able to press pinion bearings with the pinion facing up. I like that way as I know I’m not hitting the cage or anything, and am pressing on the inner race. Also be careful with stacking those press plates on those pieces of channel, I’d be worried about having something slip with that setup.
Nice work and good luck on the front axle!
Damn fine work sir.
All the voodoo required has me using a diff guy and paying his prices.
It's not that hard,really.It's a little intimidating,first one but really not hard. If you ever want to try,there are plenty of us on here that can get you through it without trouble.
Oooo, thanks for the tip on the lube, gonna pick some of that up. I also definitely need to get some more emory cloth, can't find mine and there were a couple small high spots on that pinion as the bearing went down. Nothing to cause an issue but made a ghost mark.
I absolutely did NOT want to stack those plates, but that was the only way I could get the spacing right. It was big time sketchy, I was watching it very closely lol. I used to work in a race shop and even then, I always hated pressing stuff. I'd use the freezer and hot plate every time if I had the time.
Damn fine work sir.
Thanks! This is my first time. I've always paid someone else to do them. But needing to do 2 axles at one time, I decided to spend half the labor money to get the special tools and give it a go. It's not bad, just tedious learning as I'm going. It's taken 3 times as long as it would someone that knows what they're doing, but thankfully I'm not in a hurry
Next one won't take 1/2 as long. Wish I'd known you were doing this,there are work arounds for most of the tools. But now you own tools,saved money and have a new skill. Even of you are an arrogant whatever that guy called you.
Chevrolado
McKinney, TX
Dave
K10/1500
If you want more practice after all this.. I have two more axles you can try and beat your lap time with. :D
*Note: likely some extra wear on the front from 4WD use.. ;)
Next one won't take 1/2 as long. Wish I'd known you were doing this,there are work around for most of the tools. But now you own tools,saved money and have a new skill. Even of you are an arrogant whatever that guy called.
Yep, I'm always game to find reasons for buying new tools lol. I actually already have 2 more 10-bolts lined up to do. My blue truck I'm going from 3.90s to 4.30s and then my tuner buddy wants to change his cammed 5.3/4L80 '93 OBS from 3.42 to 4.10.
So I tried to button up the rear axle for the final time last night. Went to remove the cross-pin aaaannndddd poop...
I had read something a long time ago about possibly needing to grind down 1 or 2 teeth on 4.56-up gears in a 10-bolt and completely forgotten about it. I didn't have much time last night, so I just put in the new axle seals and drove in the 2 pinion races in the front housing. I'm gonna pull the carrier back out to do this so I don't get shavings all in the housing
I had tried some all thread the other day on this and it didn't have enough ass to do it. It would get to a certain point and then start rolling the threads...
So I grabbed the balljoint press and did it that way. With a little C-channel, it worked perfectly
And done. So much for getting this done before the snow/ice hits tomorrow. Guess I'm driving the C10 home tonight and staying put for the next couple days
Finally got back on this and finished up the rear axle for good today. Pulled the carrier out one last time to grind down that one tooth to allow the cross pin to come out. Very carefully and lightly hit it with the Roloc disc a little at a time
Put it back in, torqued it down and rechecked backlash just for good measure. All good
Threw in the axles, had a bit of a time trying to get the C-clips in. Figured out I had to stick a screwdriver through the cross bolt holes and pry the axles inboard enough to get the c-clips in. Those will be tons of fun to get out in the future :rolleyes:
All done! Gasketed, rear cover on and fluid in with the posi additive. Threw a tire on one side so I could get a real good spin on it, everything is nice and quiet. Hopefully I did everything right! :hidesbehindsofa: I’ll get back on the front diff tomorrow
thatgermanguy
