Silver Square
- Jun 9, 2024
- Fayetteville, GA
- Jason
- Sierra Grande 15
Got a '77 K15. It's got the NP203, at least it should. I've got the low lock, low, neutral, high, and high lock on the shifter, but the truck has locking hubs. I've been driving the truck in high with the hubs unlocked, is that a good indicator that it's been converted?
I have the truck up on jack stands now, and was playing around. Hubs locked, all 4 tires spin in high, but when I shift into any other range, only the back tires spin, and there is grinding when I try to shift to a different range. I have to shut the truck off and shift to park, then put the case back into high or it'll grind badly when I try to move the lever. Shouldn't I be able to shift it while the truck is in gear? It doesn't seem to like that at all.
