How to fix loose gm steering column
77c102door
Newark
Harjeet
Ur welcome
CSFJ
Ur welcome
Or, you could have read and watched the videos in the thread you posted that in.
77c102door
Newark
Harjeet
This video seems more clearer, plus he talks about the issue about the highbeams
pgnavy
MA
V1500
HELP needed....while using this awesome summary to get to the four loose screws in my '87 V1500 w/tilt, these 2 parts fell out onto the floor....I'm like "huh", what was that sound of parts hitting the floor?! Now for the life of me, can't seem to find out how to get them back into the column....they look broken to me....damn! much thx
Camar068
10 yrs Air Force
OkieFishMan
Certified Camping and Fishing Nut
Enid, OK
OkieFishMan
GMC C2500
454/SM465
That is the single most thorough column rebuild I have ever seen. Awesome!
What did you ever do to get this fixed @pgnavy ?? I think you're right. Those do like broken parts.
Camar068
10 yrs Air Force
rebuilt mine in a vice and is all together and mostly functional.
I noticed I could not take it out of gear in the ON/RUN position. I take the key back one click and it will move through the gears. When the key is as far back as it can go, it's in the LOCK postion and not ACC.
Ideas? I did cycle the cylinder prior to installing (as a functional check). Also, when it's in the ON/RUN position and I attempt to move the shift lever, I can see the ignition rod move/torque a bit.
Camar068
10 yrs Air Force
Adjusting the switch (after disassembly and re-assembly) took care of all but no ACC. It might need a new cylinder.
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
I think you’re right. A cheap cylinder from O’Reilly’s remedied my lack of ACC mode.
cmoore
Florida
Chad
V3500
Great info,Thx
cmoore
Florida
Chad
V3500
Great info,Thx
newbie17
tx
bob
R30
5.7 tbi
Outstanding posting on tilt tear-down. Wonderful stuff!!!!!
Darstrom
Sweden
Niklas
5.7 L
Hello!
Great thread to start with..
I have a problem which I cannot find adressed anywhere. Hoping to get some answers in this thread..
I've teared down the column to the point of the pin pivot removal.
I can see the screws that might need tighten a few threads although they are not dangling loose at all.
However my problem is that the shaft is moving completely freely inside of the tube, nothing holds it centered or in place.
In other words the shaft is moving independent of the ball joint movement..
Does anyone have a clue what could be broken?
HowPoison
