NastyRay
Vancouver,Wa
Nasty
K30 Scottsdale
454ci
Just got done reading this whole thread. @NastyRay super stoked for you.
We might be getting my son his first pickup with a 454, so I was invested in your progress.
You can upload a video to YT, then allow only those with the link to view it for security/ privacy concerns. You could put the link here so we could all see.
Ya I’m going to do that! That is what hotrodpc recommended to me aswell! I’ll get started on that and Hopefully have something up this week!
NastyRay
Vancouver,Wa
Nasty
K30 Scottsdale
454ci
Well I hope you do get him a truck with a big block! It’s a great deal of fun and great to learn with! If he ever has any questions my mistakes are his knowledge
Big Chip
Michigan
Kevin
C35
No I just did it by hand at the carb.
I had the same issue with the spring off. I was working on it and forgot to hook the spring back up and as soon as it started it was probably 3000 rpm. Everything was fine after hooking it back up correctly.
NastyRay
Vancouver,Wa
Nasty
K30 Scottsdale
454ci
My problem was I had the wrong intake on for my heads! If you want a good laugh go back in the thread and check out what I mean :)
NastyRay
Vancouver,Wa
Nasty
K30 Scottsdale
454ci
NastyRay
Vancouver,Wa
Nasty
K30 Scottsdale
454ci
What oil are you running in this engine?
All flat tappet cams need a zinc additive present in the oil or it will only be a matter of time before a lifter / cam lobe will chew itself to death.
I use Valvoline VR1 in all my flat cam engines....
I 100% used a zinc additive. Wouldn’t dream of not
NastyRay
Vancouver,Wa
Nasty
K30 Scottsdale
454ci
Wtf does this go to it comes of my headlight wiring harness
350 w/203
At first glance that looks like the connector for your Proportioning Valve. It should be behind the front frame rail just off center towards the drivers' side.
NastyRay
Vancouver,Wa
Nasty
K30 Scottsdale
454ci
My proportioning valve has a prong not a flat blade like the connector? Still it ya think?
350 w/203
Mine is the same way. If your brake like is not on, hook a jumper up to the connector to ground and check again. If the brake light is still not on, it's something else.
NastyRay
Vancouver,Wa
Nasty
K30 Scottsdale
454ci
Ok issue my headlights are not working but my brights are! Anyone got any ideas. Replaced the switches and checked all my grounds
Its a pretty simple circuit. If you are getting voltage at the connector, your bulbs are probably burned out or the ground connection to the core support isn't clean. If not voltage than it has to be either the main headlight switch or the dimmer switch.
350 w/203
Time to dust off the DMM and start checking.
NastyRay
Vancouver,Wa
Nasty
K30 Scottsdale
454ci
No voltage at the socket. Voltage to the switch. But I’m not sure which wire should be sending voltage out when switch is engaged.
pull up the wiring diagrams from your year service manual in the reference library forum. You should be able to see exactly what wires to check to verify what is wrong
Ninao
