- Aug 3, 2010
- Usually not in Ohio
- Andy
- '77, '78, '79, '84, '88
- K5 thru K30
For those who have problems with plugs lasting a long time: How do they fail? Eroded electrodes, oil-fouled?
In my experience, Bosch platinum plugs (single electrode) last a long time with GM HEI distributors --either stock or with MSD module & coil. I have no idea why they wouldn't work for any Chevy ignition. I'm currently running basic NGK plugs in a 355 with GM Vortec heads, and they also work fine. And their plated bodies don't rust like AC and Autolite.
Also, it's worth mentioning again that there are different "reach" plugs, which is the length of the threaded portion. Also, either tapered or gaskets seats. Not a problem when using the exact AC plug specified for a stock engine, but can be a problem with aftermarket heads.
As far as the Bosch Platinum plugs go, usually they were a little eroded but looked ok otherwise. The big issue was usually misfire codes causing the engine light to pop on. Sometimes isolated to specific cylinders, but often just the P0300 random multiple misfire code. Many many times, just swapping in a different brand of plug took care of the issue.
