SquareRoot
- Mar 18, 2017
- Arizona
- Mike
- K20
She's coming to life.... It's like ******* magic.. It was the throttle plate not opened up enough.
This is why I asked if you had touched the idle adjustment screw. I went thru this too. Idle adjustment on efi can be tricky until you understand how it works. Unlike a carb, the screw adjustment is only half the equation. The IAC actually does most of the work.
Make absolutely sure the butterflies are only resting on the idle screw and there is ZERO tension in the throttle cable at rest.
The ECU resets the tps everytime the ignition is cycled. More on this later.
I'm glad she's alive!
