- May 13, 2019
- Oregon
- Eric
- K25
- 350-4bbl
The electric choke conversion for your Q-jet just replaces the thermostat bolted to the manifold with an electric one. You don't actually change anything on the carb itself.Thanks. I'll look into this. I bought a rebuild kit already, but I'd hate to find that out once everything has already been disassembled! Since you have already completed the process of changing to electric choke, is there anything that needs to be blocked off or redone vacuum-wise when switching to an electric choke version, or do just need to wire up the electric choke to a ground plus a key-on power wire and then install everything else normally? I thought about upgrading to one with electric choke, but I don't want to make things worse by getting it wrong.
https://quadrajetpower.com/electric-choke-conversion-kit-chevrolet-350-400-71-78/
