Heater Hose Routing
Jtobe81
las vegas
Justin
1981 Chevrolet
c-10
What is the correct heater hose routing from the engine to the heater core? water pump to core or intake to core.
projo198
Lawson MO
James
I just did this, and it changes between models and transmissions.
My '78 K10 is a manual and stated smaller bottom heater hose (5/8 pushing coolant to the heater core) from the intake manifold and larger top return hose (3/4) straight back to the water pump.
I think it would work either way, but my own radiator does not have a port where the diagram above shows one.
Lastly you may consider a 5/8 ball valve for shutting off the flow during the summer to avoid excess cabin heat. You'll need to order one though, 5/8 is not a commonly used valve size found at hardware stores.
tsgs84
md
Timothy
tsgs84
md
Timothy
Correct 3/4 hose goes to water pump or radiator not both, if your radiator doesn’t have a hose port then the hose goes to the water pump. This is mine.
Logbed
Europe
Caleb
C10 Silverado Longbed
Hi, figuring out the same things. The one heater hose goes to the radiator top. I had the other heater hose go to the intake with the previous engine, but is it possible to put that hose to the pump top?
82jimmy
