Heads for sale...
882 heads have 64cc chambers or something like that? Just looks a little funny brand new rockers and well used heads.
Stroked
Beloit, Kansas
Jared
882's have 76 cc chambers I believe
Sent from my Kindle Fire HDX using Tapatalk
v2500burb
Charlottesville Virginia
Jay
v2500
350ci
Mr. Clean
It seemed a bit weird to me as well
I'm really looking for some vortec heads
Any mods needed for stock vortec heads?
Some better than others?
Yep your correct, it was 202 that had 64cc chambers, that's one of the reasons everybody wants them, that and the bigger valves.
Mr. Clean
v2500burb, I don't know that much about Vortec heads. I'm pretty sure they are a direct bolt on, but you have to get a Vortec intake, because I think the heads are milled at a different angle. I might be wrong, I would check with Bucket, or Retro, someone like that would know better than I.
v2500burb
Jay
v2500
350ci
Thanks clean
I need valve seals... Truck sat forever
I figure I'm going to do that... I might as well get vortec heads
robert8096
Goose Creek SC
Robert
FYI Valve seals can be done with the engine in the truck without removing the heads. Cost is small for the parts.
OK I'll ask....How?
How do you get the spring compressor on?
Is it a special tool?
How do you keep the valves from slipping into the cylinder?
TDC each cylinder?
I'd like to know how?
Vortec heads need a different intake because the ports are taller and the bolt pattern is different.
You can keep the valve from falling in either by putting rope in there and raising to TDC, or you can hook air pressure to it. I don't particularly trust either method.
SlickGTP
Houston, TX
I've done valve springs on my Grand Prix with the compressed air method... Holds 'em up pretty well, but you have to be careful. I'm not sure how much pressure it would take to overcome the air.
Konas new ride
Alberta
Gerald
I'm going to ask the dumb question. How do i tell what heads are 882's and what heads are 202's.
882 is the last three digits of the casting number on the heads in question. "202" is actually 2.02, as in the intake valve size. 882's used the common 1.94 intake valves. 2.02 was used in some of the earlier performance heads (known as camel humps or double humps because of the casting mark on the cylinder head) as well as a few versions in the late 60's and VERY early 70's. 882's have been called "the best of the smog heads".
robert8096
Goose Creek SC
Robert
OK I'll ask....How?
TDC each cylinder?
There is a tool you use to push down the spring to remove the keepers.
http://www.tooltopia.com/kd-tools-2078.aspx?utm_source=pricegrabber&utm_medium=cse&utm_term=KDT2078&utm_campaign=pricegrabber_r1
Top dead the cylinder and use compressed air or some rope into the cylinder to hold the valve in place.
http://www.youtube.com/watch?v=OsGqmOQus6Y
F1r3truck
