Rusty Nail
- Jan 29, 2015
- the other side of the internet
- Rusty
- C20
- 350sbc
*crickets*
Older repaint.
I see "white" underneath - the original primer color should be black (unless it was built in Janesville. Then it "could" be gray).
K
I need to remove mine, too. PO sprayed over them. Heh.Agree, typically black under the paint.
Also as @legopnuematic mentioned there is a plastic protection in front of the rear wheel.
Mine is original paint but I surgically them removed with some aircraft label remover.
Mine were all cracked and made the paint look terrible.
That's good info. My '88 Burb must be a Janesville truck.
What was the last year for the red oxide looking primer?
For what it's worth, my Oshawa built '78 K10 is in red/orange primer.
Early in the lifecycle.
They were already ELPO dipping (which is black) at Flint when I started in 1979.
Although - Janesville didn't build squarebody Suburbans. Only Flint.
K
Maybe someone may’ve reskinned the door and used panel bond?
