Guess The Tool
fmxr47
US
Justin
fmxr47
US
Justin
Blue ox, is it a bearing/race or seal driver?
350 w/203
Long reach, tight space, 90 degree screw or whatever driver.
A tool made to get to something a dumbass engineer designed.
fmxr47
US
Justin
Yes and no lol, specifically designed for one job but you’re correct on the concept of the tool. It’s powersports related
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
I take it you restored the faller's axe? And more to go? A Canadian logger can appreciate this work.
They go nice with your knife collection.
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
Negative.
If it helps, the small end is exactly .200" in diameter.
Blue Ox
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
So, here's the concept. You are trying to machine a piece based on a drawing that says you need to drill a hole 1.250" from the side of the piece. Well, how do you know where the edge is?
Since a picture is worth more than my explanation I'm going to use a video. Because it is a dynamic measuring instrument it's much clearer in video.
Blue Ox
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
Were getting down to the tough ones now. This one I suspect you will never get. (Just because there is not much to it, and its geometry really doesn't give much of a clue as to its specific purpose) -
Transmission pilot bearing driver?
I was also thinking straddle bearing (? the one that supports the pinion end in a 10.5" rear) driver, but it's probably too small for that.
Blue Ox
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
A BTW, on that previous video:
With a mill that has .200 graduated dials (which would suggest a .200" edge finder) I usually set the dial at .100" when the edge finder pops so the center of the quill is at .000". Not sure why the guy in the video sets it at .000 and then resets it later. Seems like a way to introduce error.
350 w/203
Thanks for sharing that video!
Blue Ox
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
Hopefully not too easy:
Camar068
10 yrs Air Force
that like a tractor tire plug-a-muh-jigger?
1975sq
