Guess The Tool
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
Good guess, and makes sense. But not it.
Blue Ox
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
I guess it's not so easy after all. :p
The nature of that threaded piece should give you a hint.
Camar068
Kentucky
10 yrs Air Force
used for diesel fuel pump timing? Guessing old school.....and no I don't know **** about diesel lol....just playing the game.
Keith Seymore
Motor City
Keith Seymore
R10
4.3L
Been busy at work but I have a few minutes, so let's close the loop on this one:
It's a tool for checking the clearance when making a stroker crank.
You have the base crank offset ground (like say a 4.00 crank offset 0.125, to make a 4.25 crank). Install the rod on the crank and insert this device in the wrist pin hole. It has the necessary clearance built in to the larger diameter so that you can swing it around the crank weights and verify the operating clearance - or - mark the spots that need a little work in order to provide the clearance.
K
Keith Seymore
Motor City
Keith Seymore
R10
4.3L
Awright - these are what I have building up towards.
I found them in a box of stuff when my dad passed away. I honestly don't know what these do, so I am open to suggestions and comments.
K
MrMarty51
Eastern Montana
Martin
K
Top pic. looks like a double ended doodaingrrrrr.
Oh wait, that's what two girls use. :anitoof::happy175::happy175::happy175:
Blue Ox
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
And your participation is much appreciated. :)
That's the only way to keep a thread going.
Blue Ox
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
old school AN fitting tool?
Correct!
For those still scratching their heads it's a mandrel that is used to assemble hose fittings. The outer piece that goes over the hose gets put on the hose. The inner piece gets attached to the mandrel and the pin acts as a guide to keep the inner piece from cutting the hose and the handle helps screw the two pieces together.
Blue Ox
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
K
I'd guess the first one is used for a depth measurement. The surface of the piece with the hole would be even with whatever the other two pieces are attached to and a depth mic could be used with no additional math. What it fits OTOH, no idea.
Keith Seymore
Motor City
Keith Seymore
R10
4.3L
Good thought; thank you.
And likely, as evidenced by the earlier pinion depth tool.
Even if that is not it, now that you have mentioned it: that's probably what I will use it for!
(lol)
K
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
Okay...so here is a tool that I use on occasion. ..try to guess what it is used for........
This may be a tough one for you guys.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
I’m gonna guess some fed spanner wrench.
smoothandlow84
Steve
Here is a hint...I own a wood flooring company....
