GMC-IH
dragstews
Belleview Florida US of A
Jesse
Body 1954, frame 1975
R-100
406 ci SBC
The holes drilled in the cylinder bore is to stop the cracks from traveling ...
Took another cut ( .050" over stock bore now ) just to throw some cutting powder on the cracks in order to allow me to see the cracks more clearly ..
HotWheelsBurban
Houston, Texas
Carol
R2500 Suburban
This motor is just like the Bird of Phoenix .
Born from ashes !!
That graphic should be on the truck somewhere!
dragstews
Jesse
R-100
406 ci SBC
On the underside of the hood maybe?
Grand idea ..
I did shoot bed liner on it ..
Be some backing up work to do the bird ..
Might be best to settle for a keychain ..
CountKrunk
SW VA
Count
C20 Custom Deluxe 3+3
v8 350
You could slap a high quality vinyl sticker on the underside still i would think.
dragstews
Jesse
R-100
406 ci SBC
Those dang oil gallery plugs are a PITA to remove from the block ...
This tool works with a 1/2" impact gun ..
Should be easy work without the words that would make a Preacher blush !!
Whoa ....
Kind of jumped the gun ..
Had to cancel the order for this kickass tool ..
Being my SS check is late on getting here, didn't have enough green in my bank account to cover it ...
dragstews
Jesse
R-100
406 ci SBC
Jeez @dragstews how much was the tool??!!!
With Fedex shipping came to $65 ..
Has a lifetime warrantee, I liked that part ..
Went to my buddy's shop next-door to mine, he had a Taiwan kit that got the plugs out of the back of the block ...
They was 1/4" square, the plugs in the front was allen and put up a hell of a fight ...
That's one that finally came out ..
One more to go ...
Do hope it won't be as tough as this one was to get out ??
Nope, same gig as the first one ...
Drill and easyout ...
Now the oil passages can be cleaned with running a nylon brush though them ...
dragstews
Jesse
R-100
406 ci SBC
New return spring looks much better than what I did have ..
Took a bit of lathe work to make it jib with what I have going on ...
dragstews
Jesse
R-100
406 ci SBC
Been many a moon since I worked on a W Series Big Block ..
Buddy has a 61 Bubble Top Chevy with a 348ci in it ..
He's wanting to go though it and get it back to looking like new again ...
The car has really low miles on it, everything in the motor should still be at STD ..
Fixing to find out ..
Meanwhile ...
Got a bit more work done to the 454 ..
All the belts are on ..
Hoping they will stay on at 6 grand ??
Tracking looks great now .. Took a bit of work to make that happen ...
Also got around to fabricating a mount for the oil tube & stick ..
Got a good start on it ..
A little more welding and dressing in, be ready for paint ..
dragstews
Jesse
R-100
406 ci SBC
Fuel pump and line is next on the 'todo' list ..
Going to attempt to make up a hard line like how GM did it back in the day ..
Waiting for the pump to show up from Amazon ..
Got a few other parts that I'm also waiting for ..
These two items are mostly for dress ..
dragstews
Jesse
R-100
406 ci SBC
Think this should work, if there is room for the hose ??
Second line might work better .. ?
With using a 90 degree fitting at the pump should not be in the way of the lower hose ...
Will pick up the hardware to do this mod tomorrow .. Do think this fuel line will be the ticket ..
dragstews
Jesse
R-100
406 ci SBC
Much better ..
Working on the clamp, should have it nailed on in a short ...
Done, should hang tough ..
drowe14
