Garage And Shop Safety
davbell22602
Bunker Hill, WV
I Dont
Have
One
What about using a engine to raise the front end up by the spindles/axles on each side on a riding mower to remove and sharpen/replace mower blades?
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
That would work, but it's a lot easier to just drive up some car ramps to change blades.
davbell22602
Bunker Hill, WV
I Dont
Have
One
I dont have car ramps. I guess I should find good set of car/truck ramps. I dont want those plastic ones that are out there.
f1shman
Never leave a commercial grade battery charger on unattended. We had a tech come in on his day off and leave one of his batteries hooked up to the charger in the shop. He never came back to get it at the end of the day so it sat overnight. The next morning the case of the battery was all distorted and bloated sitting in a puddle of acid on the floor of the shop.
Since I'm on the subject, let me share with you a few other things concerning safety that I picked up so far in my lifetime. The wonderful folks at O.S.H.A. say that every hazard involved in the use of power tools can be prevented by following five basic rules:
  1. Keep all tools in good condition with regular maintenance.
  2. Use the right tool for the job.
  3. Examine each tool for damage before use.
  4. Operate according to the manufacturer's instructions.
  5. Provide and use the proper protective equipment.
Now that list works for most things, but there are always additions to be added.
  • Always inspect your tools before use and check for external and internal defects such as frayed cords, broken handles, cracks in striking surfaces... etc.
  • Remove damaged equipment from service and attach a do not use sign immediately if you can not fix it right away.
  • When using wrenches and ratchets always pull the tool toward you, do not push.
  • When using knives always cut away from you.
  • Keep your blades sharp.
  • Don't use extenders or cheater bars on ratchets or wrenches.
  • Keep your tools clean to prevent slippage.
  • Stay aware of your surroundings. Keep firm footing and maintain your balance.
  • When working on electrical parts always disconnect the electricity.
  • Do not use cushion grip pliers on active electrical circuits. (see above)
  • When using an impact, do not hold the socket, universal joint or other attachment in your hand while the tool is operating.
  • Do not continue to hammer with an impact tool once the fastener is tight.
  • Do not use hand tool sockets on power tools.
  • Don't use metric tools on SAE fasteners, or vice versa.
  • Always use a box wrench if possible.
  • Utilize commercial lubricants to their full potential. Let the oil do the hard work for you.
  • Do not exceed the capacity of your torque wrench.
  • Do not use your torque wrench to break fasteners loose.
  • Do not use a torque multiplier with an impact wrench.
  • Never point the sharp end at other people. Good for knives, chisels, saws... you name it.
  • Do not use cold chisels on concrete.
  • Use a punch or chisel holder to prevent hand injuries.
  • Do not use an impact wrench on any puller.
  • Never place your finger on the start button (or trigger) when transporting a power tool.
  • Never remove the guards from your power tools.
  • Always dress appropriately for the tools you are going to be using. (No loose fitting clothing, rings, loose jewelery, keep your hair pulled back... etc.)
  • Check your power cords before use and only use the double insulated (3 prong) plugs.
  • Do not raise or lower your power tools using the electrical cord.
  • Just :grd:
There's always more to learn and add to this list so as I find new things that might work here I might just do that.
davbell22602
Bunker Hill, WV
I Dont
Have
One
I used a impact wrench on puller. I used it to pull those double pulleys thats on a riding mower. Whats a punch and chisel holder? I just use vise grips.
f1shman
I got the plastic ones and I love them. Had them for 5 years now, hold up well. Even for the Burb. :waytogo:
http://www.harborfreight.com/punch-and-chisel-holder-67094.html
Vice grips work, but they aren't as comfortable to hold onto tightly as a punch and chisel holder.
That's neat, never saw one of those before. :hmm:
Pretty good list there F1sh. Only battery charger I ever leave unatteneded is a 2amp trickle charger overnight. And If I am using 10 amp, I do it outside so I don't forget, and always a good idea to charge in a well ventilated area anyway.
RetroC10Sport
Green Bastard Parts Unknown
Jay
pontiac aztek
davbell22602
Bunker Hill, WV
I Dont
Have
One
I saw the whole video of this at school but here's 3 minute version of it that I found on you tube.
[yt]cVgKyADdIBQ[/yt]
****** video there Dave. Obviously just a sales video playing on a bad situation to sell videos. That's what you just posted is a commercial to sell videos.
davbell22602
Bunker Hill, WV
I Dont
Have
One
I know its all I could find of it. The video is called Remember Charlie. This the link to watch the demo of the video.
www.remembercharlie.com
Todays Garage Safety Tip : DO NOT try this at home !!!
attachment.php
dhamp
Atlanta Area, GA
Derek
R-10 Custom Deluxe
I'm late to the party, but no breaker bar extensions on your ratchets? W/out and impact wrench, I couldn't do 1/2 the stuff I need to do w/out sliding my trusty 1-1/2 galvanized steel pipe over my ratchet!
Ender
