Fuel pump pushrod won’t slide into block
iamtherealJayy
Tennessee
V20, K10, K10
So I bought a K5 blazer a month ago and it has not moved at all. It has an electric pump but it lost prime and stopped pulling out of the tank. I gathered all the stuff to throw a mechanical pump on and I can’t get the rod to slide in? The bolt in the front is mia, I took a 3/8” 6” extension and it slides in without issue. I put grease in the pushrod and it slides about a inch n a half then just like hits a brick wall? It was a used pushrod but I threw it in a drill and used 600 grit sand paper and cleaned it up looked like a mirror stick so I know it was clean. Block is an 088 or 880 I’m not sure but you can see those numbers by the starter so it’s not the original block(obviously since it was originally a diesel, but still not a original carb 350?) any suggestions?
iamtherealJayy
Tennessee
V20, K10, K10
It only goes a little over an inch, I put a 3/8 drive 6” extension and it slid right in without issue. It’s just a hair and a half smaller than the rod
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
Also check to make sure there isn't too long of a bolt going through from the front of engine near fuel pump boss stopping the rod. One of the holes in the casting does go through to the fuel pump rod. It's designed to hold rod up and in to allow easy pump install.
iamtherealJayy
Tennessee
V20, K10, K10
Mentioned bolt in first post, it’s MIA. I’ve never experienced this so I have no idea
iamtherealJayy
Tennessee
V20, K10, K10
Me aswell. Main thing keeping me from getting this unit running. The electric pump won’t pull fuel from the tank anymore
iamtherealJayy
Tennessee
V20, K10, K10
I put grease on the rod and it goes around 1-1/4” in, I can’t see it all from one angle, I laid under the blazer to see the bolt missing, I did from above to see the rod not going in. It’s got a 6” lift it sucks to work on honestly.
Say that is the culprit, however would I go about fixing it?
squaredeal91
Greg bush
1991 SB
Can you get something all the way through that 3/8 bolt hole in the front like a stiff wire maybe?? Just to know that there isn't a broken bolt in there or maybe with pin out run a long bolt through that hole to hopefully clean out any possible rust?
iamtherealJayy
Tennessee
V20, K10, K10
I can’t seem to shove a piece of wire more than an inch or so into that hole
iamtherealJayy
Tennessee
V20, K10, K10
That ledge back in there is what’s stopping me.
squaredeal91
Greg bush
1991 SB
Oh no... looks like the old pin broke off and is stuck in there??
iamtherealJayy
Tennessee
V20, K10, K10
It’s hollow, that lip is what’s stopping me, is there different fuel pump pushrods that are lesser diameter? I can put a 3/8” rod in there without issue
iamtherealJayy
Tennessee
V20, K10, K10
Is this hole something that can be enlarged or do I need to find a different rod or shave this rod or is there bigger issues or
MTBR12
