Fuel lines and cap
theBIGnaud
California
Ryan
K-10
Vortec 350
I have a question. I dropped my tanks and cleaned/painted them. The sending unit has TWO ports. One of which is capped tight. The other each goes a three port tank selector valve. My question is, should I vent the capped line or get a special gas cap? Does anyone know which one to get? The emission ones only vent in and not out right? Thanks!
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
If smell is not a concern, both would be about the same. If you vent the line, you need to put an inline filter on a small piece of rubber line so it doesn't suck dirt in. Or you could do an old style vented cap (yes, outward). Is your evap canister there? I'm not a tree hugger by any stretch of the imagination, but I prefer this way so my stuff doesn't smell like a gas station, and you don't have to think about it. Plus, it's not in the way.
da_raabi
Trailer Park Supervisor
FloriDUH
Adam
c30
On my Camaro I used a small charcoal filter that is often used for filtering the vacuum air going to a brake booster. I just hooked it up to the vent outlet on the tank then ran a bit more hose up to the frame rail under the trunk. Its been sitting like that in my garage for a couple weeks with about 3-4 gallons of gas in the tank and I've got no smell. And I have a sensitive nose...
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
Like this one?
da_raabi
FloriDUH
Adam
c30
Like this one?
Yup, thats pretty much exactly it. The one I used was a Dorman 80195. Looked just like that. $9.95 on Amazon. Seems to work for me so far!
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
Hmm, that's a really good idea!
jdc72cutlass
