KamperBob
- Mar 16, 2024
- Somerwhere USA
- Robert
- k30
- 6.2?
So I'm bringing back an 84 k30. This past week was my first trip camping in the San Bernardinos. Going up it did okay. Coming down yesterday a leak developed. Apparently fuel from the box filter bleed port. I was concerned it might've been something more serious. But could it just be that the bleed screw wasn't seated tight enough? I hadn't touched it. Nor checked it. I pulled the screw and the pointed bottom looked fine. So I made sure it was snug.
Before that, however, I didn't even know that it was the bleeder. I thought maybe it had to do with water in fuel and purging. So I rigged up a catch bottle to examine and make sure what it was. Then after studying available manuals and online searches today I learned it was the bleeder. So it's supposed to leak when opened to purge air from an empty new filter. Not otherwise. So I'll leave the catch bottle and monitor to see if any more presumably unwatered fuel comes out. I just ran to the store tonight, maybe 10 miles round trip, and so far so good. But I'm planning a longer camping trip into the Sierra Nevada next week. I'll have more data after hundreds of miles.
Meanwhile, I'm puzzled because the shop manual said the water in fuel sensor was in the tanks and mentioned a purge siphon by the frame rails. So far I haven't found that. Maybe I'm just missing it. I hope to trace down the sensor wires to confirm. The shop manual also shows the water fuel separator, including drain, on the fuel filter. Is this just a case of belt and suspenders? The dash light comes from tank sensors and the larger volume of water at the root source can be siphoned there, yet what gets up to the filter can get trapped and drained there as well? Or is the water in fuel sensor in the filter housing? That 411 might help. TIA
