Front sway bar recommendations
rwljpl
Alabama [AL]
Rich
Advice on a sway bar for a 1985 k10 with 2” lift
Addco or LMC?
Do I need any special mounting hardware since I have some lift? Anything I should know before installing?
Thnx
Dutch Rutter
Independence, Or
Joshua
Most people here suggest removing the sway bar on a 4x4 and call it a day. But the LMC should be original equipment and will work. Nothing special needed unless you are 4" or higher in lift. That is when binding can be a problem.
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
Oop, sorry. I missed where it was a 4WD. But still, it depends on your purposes. On the street a swaybar is a good thing, but offroad not so much. Most offroaders use a detachable, since off road, articulation is king. But once you're back on the road a swaybar becomes a good thing again.
rwljpl
Alabama [AL]
Rich
Yeah, I’m on the street which is why I’d like to have it. Thanks for the help!
omillan99
El Paso, TX
Oscar
K20 Scottsdale
350 4 Bolt
Not sure if you had fixed your issues with this but ORD has a Disconnect kit to switch between on and off for on-road and off-road use. AFAIK you use your stock sway bar and attach it to the axle. But it does require a minimum of 2 IN of lift which you do have.
https://www.offroaddesign.com/catalog/swaybarkit.htm
Tim O
