Front driveshaft - longer on a NP203 vs NP205 ? Same mount ?
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
Morning all ! I was looking at gear ratios for NP203 vs NP205 low and stumbled across a post saying the NP203 would use longer driveshaft. My OE driveshaft is too short with the 4 inch lift (on the Sub when I bought her) and maybe a new shaft to fit a NP203 would be less than having mine redone. I am not charging transfer cases, that is just how I saw this web info.
But ...
Anyone know if the transfer case side mounting for the driveshaft would be the same? I need a longer driveshaft and I see where I can get a SKP936110 from RockAuto for $ 215.00 plus shipping. That's cheaper than I can get mine redone for. :Big Laugh:
TIA !
Britt
Bowtie-dad
Wyoming
Brad
V35
7.4l
This is a double cardan 1350 drive shaft from a 1ton with a 205 t case and Dana 60 front diff Tom woods can build a custom one to fit your rig after some measurements and they are pretty cheap I believe 349 is for the 2 inch tube. I've opted for the 3 inch tube and 16 splines slip shaft to hold all the power it makes and it was 645 with free shipping and a lifetime warranty.
Sm465 gearbox with 205 and either Dana 44 or 60 front the collapsed length I believe is 24 inches plus 3-5 inches of slip yoke movement in some cases. The one in the photo is a one year only 4L80E auto 205 t-case with 60 Dana 60 front and compressed length is 34 plus 3 inches yoke travel
As for the length of the front shaft it would be shorter if you have a manual transmission vs an automatic. The 205 and 203 were used in more than Chevy trucks. I believe if you are using either t case from a Chevy they should be passenger drop Ford and dodge were driver drop but don't quote me on that, have seen too many things that shouldn't have been. Lol
I wouldn't change out an np205. That's a full gear drive unit cash iron housing and worth some cash. Much stronger than the 203. I believe the 203 is sprocket and chain.
Strick
Dunn, NC
Harold
C20 Crew
The front shaft should be the same length for an NP205 or NP203. The rear shaft will be shorter on an NP203 because the case length is longer. I definitely would keep the NP205 & get shafts to accommodate for the lift. SM465/NP205 are the best combo hands down.
HS
But ...
TIA !
Britt
You should have capitalized underlined and quoted" I AM NOT CHANGING TRANSFER CASES" You'll know better next time.
DonN
Rio Rancho New Mexico
Don
HS
No it's not. The 203 shaft is longer. I just put a twin stick 205 behind a TH350 in my K10 and had to have the front shaft shortened and the rear lengthened.
Strick
Dunn, NC
Harold
C20 Crew
Is it a Dana 60 truck? I know that doubling the cases makes for the length difference but I've never had to replace the front driveshaft when doing the 203/205 swap. It was only the rear that has been different. 60 housings are much bigger and may take a shorter driveshaft if no lift is installed. TH400 transmissions make a difference too.
HS
ali_c20
Austria
Alexander
C20, K5
When I did the swap 203 to 205 on my K5 I had to have the front driveshaft shortened and the rear lengthened. I have a TH350 and GM corporate axles.
Goldie Driver
Houston, Texas
Britt
GMC K1500 Suburban
Do you remember if the transfer case end of the driveshafts were the same ? ( Round mounting flange) My thought was to buy a 203 front driveshaft shaft and gain the extra length needed for less than what the drive train shop could lengthen the old for.
ali_c20
Austria
Alexander
C20, K5
The ends were the same.
erikm00
