iamtherealJayy
- Nov 26, 2021
- Tennessee
- Jacob
- 1987, 1978, 1976
- V20, K10, K10
I have decided to dedicate this issue to its own thread, since it has really started bothering me more and more not being able to figure it out.
I have a 1987 Chevrolet V20 and the front axle is sitting offset to the passenger side, no big deal except that the passenger side of my trucks stays filthy since the tire is way out of the fender. I have revently replaced the front leaf springs and all new steering(minus ball joints) the truck was off centered before and passenger side sat a couple inches higher than drivers side. The truck still isn’t level and axle is still out passenger side. When I got the truck it had aluminum lift blocks in the front, the passenger side had the alignment pin broke off in the spring perch(woohoo found the problem.. I thought) truck is sitting on pro comp 2.5” lift leaf springs front and 2” steel blocks in rear. I did measurements from brakes to frame in the front and came to a ~2” difference so the axle is offset around an inch. I’ve read several things on other websites about this being a fairly common problem for the front axle to be off center one way or another and it become apparent once you get different tires(I never noticed it until I got 16x10’s with “33x12.5”(it’s in metric like a 305/75/16 or something) the front sway bar is currently not on the truck as when installing front springs I was told removing sway bar could help some. Here’s some photos of currently
