One bolt for sure had a collar, so it's in there pretty far. And my welder is 6+hrs away. Tried walking It out with a round chissle and hammer, no luck. I researched all about removing bolts, and the main issue I am having is gonna be keeping everything square while drilling bc of clearance. Or remove the transmission, which requires relying on other people for a level spot, and a few tools. Not having much luck with that. Of course. And if I'm pulling trans for those, imma have a flex plate handy just cause. If I ever get that far...EZ out is the last option not the first, when I worked at the machine shop that was 1 of the most common PITA repairs we got a least 1 a week.
You drill a hole crooked and off center and now you snap off an EZ out in this crooked hole which I then have to get out the broken rd out, and then try to redriill your crooked off center hole and retap it. Try walking the bolts backwards with a punch, no dice can you weld a flat washer and a nut to the offending bolt nd back it out? Drill bit on center and straight drill a pilot hole and then proper size hole as indicated on your tap. Now you can collapse the threads in with a punch and pull them out.None of that worked well you have the proper size hole in the proper location tap the hole slow and careful.
I've been asking myself the same question. But if I replaced the balance and plate, I bet she'd run like a top. Shes off balance on at least one side if not both. I bet imma end up doing both asap. And if that doesn't help my problems at least a little, then shes gonna turn into a cheap thrill for someone else, or scrap yard material.Upload it to you tube and link it here.
Those "grinded off humps" are clearances for internal pieces, ignore them.
That's a good transmission.
That first post was pretty good l, you made a rhyme and everything that time.
Uumm if your balancer is separating you should replace it and it forces the question if that is the cause or an effect.
Let's ride into the sunset togetherAgreed. Replace the starter and shim it properly, then ride off into the sunset.
I'm riding off into the sunset with your 400 Small BlockLet's ride into the sunset together
Stirrup to stirrup, side by side
When the day is through, I'll be here with you
Into the sunset we will ride
he was talking about my 400 from another thread, the OP has a 350 i believe and I have a 400, but it originally mated to a th350 which is still in the truck it came out ofDamnit!
Are you soaking them broken bolts yet?
With the PB or somethin?
Wait wait wait wait.
You runnin a 400?
I broke a 400 flexplate pretty easy I think from spinnin it too high.
You with the forward to reverse or wtfe.
How the
U got a 400/400?
For real?
Pix!
If you like 400s, well, I got a 2 speed powerglide with your name on it rustyMmmm 400/400....fapfapfapfapfap![]()
Think you are making more work for yourself than necessary by messing with the flex plate. Sure it's a little chewed up from the starter not mating properly but it's not missing a bunch of teeth or anything.I've been asking myself the same question. But if I replaced the balance and plate, I bet she'd run like a top. Shes off balance on at least one side if not both. I bet imma end up doing both asap. And if that doesn't help my problems at least a little, then shes gonna turn into a cheap thrill for someone else, or scrap yard material.
So, I planned on playing a game, post a picture and see who caught on to why I'm having issues. But before I could have any fun, I log on and see you didn't just catch on, but you nailed it on the head. What took me 2 starters and a couple weeks, some elbow grease and a tad dash of up close and personal time with this truck,(don't forget a thousand.. ohhhhhh...that's why moment s) you calmly threw out the piece of information I needed like it was common knowledge.I'm riding off into the sunset with your 400 Small Block
