Fair price to switch a V10 front and rear diffs to 373 from 308 gears
Shoote
florida
tim
Hello Everyone,
I have a 1987 V10. It currently has 308 gears with open differentials. I installed a larger engine and a larger stall converter in the 700R4. ( 2000-2400 stall ). I want to change the gears in the differentials to 373 with a limited slip in the rear. So far I have 2 price quotes, one is $3,200 and the other is $3,400. This seems very high to me. Does anyone have any input on this pricing?
gmbellew
Kansas city
glen
suburban 1500
that price seems very fair for both axles if everything else is in good shape and no extra items need to be replaced. if something else needs to be replaced, then the price will go up some. I'm in the midwest.
Camar068
10 yrs Air Force
I'm looking to get mine replaced at some point. The last set before covid cost me about ~$600. For the same job now I expect to be told $1,000-$1,200. Thats with (now and then) me supplying the gears and install kit. It's ~$500 for 2 sets of Richmond Excel.
If anything, call smaller semi truck places with a good name and maybe get a better price (or be able to trade stuff you got for the labor).
These are things I'm doing here in BFSEKY to get better pricing.
Strick
Dunn, NC
Harold
C20 Crew
I just swapped from 3.08 to 4.56 on my '87. I put Spartans on both ends too & it costed me about $1500 total in parts. That is with me doing the work though. I can look up the labor hours if needed but it sounds like you are paying $200 an hour or better for labor by the quote you've posted.
HS
What all is involved in that quote? Brand of gears? Locker or posi? All new bearings/gaskets/seals I assume?
That does seem a little high. Around here in North Ga, it would probably be between $2000-3k for 2 axles with some kind of locker or posi. I'm in the middle of doing it myself in my daily '05 4wd. It was roughly $875 in parts (not top of the line stuff, would've been $1500 in parts if I'd done a TruTrac and higher end gearsets) and I had to buy roughly $350 worth of tools and then another $100 in fluids/seals that weren't included in the kit/misc stuff.
Shoote
florida
tim
Thanks for the input. Not set up to do this work myself, so I am just going to have to pay for it.
I'd suggest at least shopping around, get 2-4 quotes and go with whoever you're most comfortable with. I know here, 4WheelParts is about as expensive as it gets. But we have a few mom and pop places that do better work for quite a bit less than the name brand guys.
jwroblesk
minnesota
Joe
c 20
I’m looking for a 308 or so gearing for my 1974 c20. Don’t like the 410’s I currently have. I’d be looking for a drum to drum swap if anybody is interested. Joe
Soundmound
North Central Washington
Dave
Scottsdale
If you were in Washington...
Muddybuddy
VA
James
You could likely find a set of axles with 3.73’s already in then from factory for less than $500 for the set. Then pay to have them swapped it. Should be much cheaper route. Can swap your brakes onto the new axles if they are better than the axles you find. Just a thought.
jwroblesk
minnesota
Joe
c 20
That sounds like a workable plan. I’ll ponder that for a it
To add to the info here, I talked to a buddy of mine that has a small performance shop about 2hrs from here to see what he'd charge since I've been struggling doing it myself. For all bearings/seals/new set of gears, no posi since I already bought one and labor was gonna be $1200-1500
jkp060608
