SCtractorboy
- Jun 22, 2016
- Gaston, South Carolina
- Josh
- C10
- V8 305
I figured this was a ignition issue as I would let the engine warm up and it shut off once it had warmed up. It didn't choke out or anything as it would when starving for fuel. Once I allowed it to cool, several hours later, it would start back up again and repeat this process (for for about 10 minutes til warm and then just stop without restarting). I've been on the way to work and it just shut off and leave me on the side of the road.
I started by replacing the plugs and wires. After this it ran perfectly for a few days without any issue. On the way home from work (maybe about 5 minutes after I left) it just shut off in the middle of traffic and I had to pull off. Again, it would not start back up. I went back the next day to try starting it and it run like there was no issue and I made it all the way home, which is about a 30 minute drive. Made it home, it idled soooo smooth and then I shut it off. Go out a couple days later and it won't start at all.
Researched anything and everything I could about ignition issues and decided to replace the ignition coil. Replaced it this morning and still nothing. Only other thing I could figure is the distributor itself or timing.
I recently replace the fuel pump as well (like within the last 6 months) so I wouldn't think it is an issue.
