Engine mount, old or new?
Logbed
Europe
Caleb
C10 Silverado Longbed
I have heard two opinions
1. Old OEM after 40 years is still better than new chinese
2. Replace them as the engine is out now.
Its not about money. The new rubber ones available here cost 20-35$. Whats your opinion.
(the small cracs are more visible in images than in real life)
ali_c20
Austria
Alexander
C20, K5
Rubber ages and with 40 years it's pretty dead. I had to replace the engine mounts on all old vehicles I owned. Some were terrible worn some not too bad but still dead. I replace them with polyurethane inserts. I used the Summit brand and they are not much stiffer as the rubber versions.
Polyurethane is very resistant against oil, gas and all that other stuff in the engine bay. My 0.02$.
Toad455
North Texas
Kevin
I used these in the factory metal "clam shells" for my 78 C10 : https://www.summitracing.com/parts/ens-3-1116g/make/chevrolet/model/c10/year/1978
Logbed
Europe
Caleb
I ordered OEM style Anchor mounts. Lets hope they are good.
fast 99
Spokane, Washington
I usually replaced the mounts. Many times upper bracket attached to the block will be laying hard against the cross member or frame. Even if it isn't will the old mount last as long as the replacement engine?
Anyone who has replaced this style mount [engine installed] will attest they are no fun. Much easier to do when engine out.
I think it always pay off to go with new, but spend some time looking for a higher quality product. Maybe the off-road vendors sell some HD engine mounts?
With a C20 you will probably pull the engine and trans as one unit, so reinstallation might be not that difficult. With a K25 like mine you have to pull the just the engine, and then get it lined up again with the transmission as you drop it into place. I think I tried just dropping the engine in and lining up the mounts enough to slip the pivot bolts back in, but I couldn't line up mounts and drop the engine at the same time.
IIRC, I bolted the complete mount to the engine, then dropped the engine in place on the fame and slid it back to meet the bell housing. Then I used the hoist to take enough weight off the engine so I could jockey the front of the engine around until the motor mounts lined up with the holes in the frame. Not much fun, and lots of possibility for pinched fingers.
Logbed
Europe
Caleb
Things turned out so that the Anchors were not available. The cracked rear mount convinced me not to buy far east rubber, so I Installed Energy Suspension urethane inserts. I'll let you know how they are once the engine is in and snow and salt are gone from the streets.
If your engine moves around a lot esp with a broken t case mount(or transmission), you can twist the buckets that those mounts bolt to. Because of my truck having that problem, when i get to it i will be doing the ORD mounts i linked in previous post
Will also upgrade the t case mount to something stout
kobedemello
