Engine Backfire Diagnosis Led to Wiped cam Lobes
350runner
tx
Ceasar
85swb "Fancy"
Summit suggest you use the GM intake torque sequence... See pic. Start with 10ft/lbs then 15, last 25ft.lbs.
350runner
tx
Ceasar
Get a vac gauge bud. It will tell you the what's wrong with your engine. I thought you said you had gotten one a while back for seeing the a/f screws. With out it.. it's like the blind leading the blind...
Skweegle89
Oklahoma
85swb "Fancy"
This fella helping me told me not to buy one because he had one. Turns out he doesn't so now I have to pick one up when I go back to the parts store.
350runner
tx
Ceasar
Good deal.
Skweegle89
Oklahoma
85swb "Fancy"
The beast is alive. Got it timed. Idles fine. Couple of things tho. When I hit the throttle, it takes awhile to come back down. 4 or 5 seconds. It's not instant. Also, I'm only pulling 2.5lbs of vacuum at idle and I don't have a vac leak.
350runner
tx
Ceasar
What's the timing set@? Have you tried audio adjusting the a/f screws? 2.5 is low
Skweegle89
Oklahoma
85swb "Fancy"
Timing is at 12*. I brought the a/f screws out to 2 full turns with close to no change in vacuum.
Skweegle89
Oklahoma
85swb "Fancy"
I know this big cam won't allow for much vacuum, but 2.5 seemed low to me too.
350runner
tx
Ceasar
Yea you just have a cam with a Heck o lot of duration is all... have you taken it for a ride?
Carb'ed Vortec 350
2.5 lbs at idle? Does a ported port pull that low of vacuum at idle? I have never put a gauge on one. Could possibly be a vacuum line connected to a wrong port? Just brainstorming.
OOPS, WAS A LITTLE LATE...LOL...
Skweegle89
Oklahoma
85swb "Fancy"
Just got back from a ride. When I shift into 3rd and give it gas it stumbles and pops out the carb once and I have to let out of it to let it catch back up. Running too lean?
Skweegle89
Oklahoma
85swb "Fancy"
I tried it on 2 separate manifold ports.
The only lines I have going to the carb are the vac advance and the pcv valve. All the others are plugged.
350runner
tx
Ceasar
UN plug that vac advance till you get it limited...
kobedemello
