Electrical and Harness Repair Parts
What's done is done, and it doesn't look to ungodly. It's not your typical type truck anyway with that ramp wrecker bed on it. I think I'd just leave it as is. Sometimes once the stuff is added, it's a real bitch to correct what once was. If it all works, isn't broke I'd just leave it. Maybe pull the wing off. Not much of benefit to that at all.
That truck is sweet.
Posted from mobile...
oneluckypops
Sedalia, Mo.
Luke
K30 SRW
Here is a link to an auto electric supply retailer. It appears they have just about any connector you could need to repair your harnesses or build your own.
http://www.repairconnector.com/
Feel free to add links to other auto electric repair related links.
Here is a link to Painless Wiring products. I avoid these when I can since they are very painful in the ass where my wallet sits. Easy to use products if you want to spend the big bucks.
http://www.painlesswiring.com/
Holy Crap there prices are outrageouse. www.Eficonnection.com is a decent place to buy the stuff.
hatzie
k20
If you know what terminal family you have it helps.
The detective work is made easier by having the GM factory wiring diagrams. The connector shell part numbers are in the factory wiring diagrams. Google those part numbers and you'll usually be able to identify what family they are.
Pak Con, Packard 56, and Weatherpak are the most common connectors used on the squarebodies.
This is just a list of the more common terminal families GM used on these trucks. There are others.
  • 79 & later ATO/ATC Fuse panels are mostly female Pak Con terminals with Packard 56 on the flasher relays. I'm not sure on the 73-78 AGC fuse panels.
  • Steering column, earlier wiper motors, and shaft mount radio plugs are Pak Con I.
  • Bulkhead plugs are Packard 56 & Packard 59 terminals.
  • Sensors are usually Packard 56, Sealed Metripack 150 (both standard insertion and pull to seat), and Weatherpack.
  • The 12 position ALDL jacks use Unsealed Metripack 280 terminals.
  • You'll find a smattering of Sealed Metripack 280, 480, & 630 terminals in the TBI harnesses.
  • Power window and lock switches for our trucks are GM pin terminals that are fairly hard to find.
  • Many of the ECMs used Micro-Pack 100 connectors.
Most Delphi terminals continue to be available but the connector shells go obsolete with fair regularity.
Many of the less common connector shells have an extremely large minimum order so be nice to the outfits that are selling smaller hobby quantities of them. Some outfits like McMaster Carr, Waytek Wire, Mouser Electronics, and Allied Cable generally sell to businesses but are willing to sell to the public if we behave in a reasonable manner. You are not a highly profitable part of their business you are low margin PR. Keep that in mind. Nuff said.
Reasonable prices on Delphi; Metripack, Weatherpack, Packard 56, and Packard 59 as well as a selection of Deutsch DT, DTP, & DTM series.
The Electrical Depot is the only small outfit in my arsenal. He has good prices on quality Delphi terminals & shells along with Delphi crimp and extraction tooling. Ratcheting Dellphi 12085270 & 12085271 or their less expensive House crimpers HT-10 & HT-11 will handle most open barrel terminals in two operations (conductor then strain relief on the insulation or seal).
http://www.theelectricaldepot.com/
If you know the part numbers or at least the terminal family and metric wire size Mouser has a huge selection of Delphi, Molex, and Deutsch connectors and terminals. The Mouser website is easier to search than Digikey or Newark and generally less expensive than Newark. Newark generally has bloody everything but they're like McMaster Carr and Grainger... you'll pay for it.
http://www.mouser.com
SXL Crosslink Polyethylene jacketed wire called for in the GM wiring diagrams.
Spools as small as 50'. Waytek and Delcity also have some Delphi connector shells and terminals.
http://www.waytekwire.com
http://www.delcity.net
Allied Wire And Cablehttp://www.awcwire.com/productspec.aspx?id=type-sxl
Shorter coils of SXL, GXL, & TXL wire more suited for small projects... http://www.wirebarn.com/
TRAZOII
Phoenix
Anthony
K10 Sub
Does anyone sell the harnesses from the bulkhead just for under the hood? I see painless had the whole damn thing. But I want to just re wire from the bulkhead out.
Sent from my VS990 using Tapatalk
gmachinz
Harnessworx Inc
Iowa
Jabin
I do-PM me with what underhood options you've got-I offer stock OEM replacement or I can build to suit also!
TRAZOII
Phoenix
Anthony
K10 Sub
Okay I have a question. On the transfer block on the firewall what color is the oil sender wire what color is the water temperature sender wire and what color is the choke wire for electric choke
TRAZOII
Phoenix
Anthony
K10 Sub
I ask because I've looked at the schematics multiple times and I can't figure out which one is which
gmachinz
Harnessworx Inc
Iowa
Jabin
Oil sending unit is dark blue through 1977 I believe and tan from 1978-up. Engine temp sensor is dark green. Electric choke runs through the oil pressure switch. Typically, pink w/blk and dark blue both go to the pressure switch-light blue is joined with dark blue and the light blue goes to carb choke. The pink w/blk supplies switched 12V while the dark blue is for the choke indicator light.
jimbob_2015
jimmy
silverado K30
Hope im in the right spot for this, i need to find a replacement for the connector that goes under the rear of the truck and connects the left and right rear lights together it is for an 86' k30 does anyone know a place or part number to find one. Thank you!
Battlac40
New Mexico
James
K1500 Sierra Classic
Try GMachines he is a site member.
jimbob_2015
jimmy
silverado K30
ok thank you
gmachinz
Harnessworx Inc
Iowa
Jabin
Yep I've got them. Do you need them with or w/o pigtail leads to splice to?
KOOLKIWI
