SirRobyn0
- Dec 6, 2019
- In the woods in Western Washington
- Rob
- C20
This is on my truck, 1984 C20 305 / 700R4 still running the 3.41 rear gears, but one day will be 4.56. Stock everything including suspension has the 14B semi-float w/ 2 piece driveshaft. I've had the truck for 3 years and it has had a driveline vibration since the day I bought it.
U-joints were the OE 37 year old joints until last weekend. They didn't have any slop in them, and weren't making any noise, but I'm taking enough longer trips 100 mile one way and returning loaded with feed, that I'd like to fix this vibration both because whatever is causing it I don't want it to give out on me 100 miles from home and it's also annoying. So I bought new u-joints and carrier bearing, thinking when I dropped the driveline I might find a stiff joint which I did not, but I proceeded to change the U-joints and carrier since I had it out. I saw no missing weights on the driveshafts, and everything went smoothly. And of course it is phased correctly. I put it back together and drove it today and the vibration is still there.
I guess I should describe the vibration. Feels pretty much like every other driveline vibration I've ever felt, it's at it's worst cruising or lightly accelerating in 3rd gear locked up 35 - 45mph. Unlocking converter reduces it, but it's still there. I can feel it at higher speeds and in 4th, but it's much less noticeable. Seems like it is not as bad during the first 30 minutes of driving, which to me seems odd for driveline vibration but I don't think it rules out driveshaft balance. It is not coming from the converter clutch.
Currently I'm playing around with hose clamp driveshaft balancing, for those that have not heard of this basically you start 6" from one yoke make a mark at 0, 90, 180, 270degrees on the shaft, using the head of the screw clamp as a weight you move it to each mark noting any improvements, and trying one or two clamps. I know I won't get the perfect balance this way, but if it is balance that is the issue I should be able to improve it at least. I did the end at the rear diff today with little change. I'll work my way over both haves of the driveline in the next couple of days.
I'd like to know your thoughts, if you have seen something like this before that wasn't the driveshaft, I'd like to know. I've done lots of U-joints at the shop of course, but I'm thinking I need some thoughts and maybe an idea or two from you guys. Thanks.
