Donkey. Dirt track race car build.
wanderinthru
Mid Point Route 66
Shakey
81, 70, 75, 84, 89
K 10, C 30, K 20
Ok. Engine and trans are mounted. 3 inches ish back.
Some more weight reduction.
AyWoSch Motors
The Parts Guy
New Mexico
Ayden
K1500 Sierra
350ci V8
Looking good.
But damn man, there's not much car left there, haha.
wanderinthru
Mid Point Route 66
Shakey
81, 70, 75, 84, 89
K 10, C 30, K 20
Decent progress made. Seat is mounted.
Pedal assembly is finished and has pads.
Down bars, cross brace, fuel cell mount is in, its cage is started.
More coming soon, if them little ducks will stay rowed up.
wanderinthru
Mid Point Route 66
Shakey
81, 70, 75, 84, 89
K 10, C 30, K 20
Finally, been wanting to cut that piece out for a while. If I ever build another one of these, the body is getting taken plumb off first.
Hope to get this rear end out, and the ford 9 inch fit up ad going back in this weekend.
wanderinthru
Mid Point Route 66
Shakey
81, 70, 75, 84, 89
K 10, C 30, K 20
Hoop braces for the fuel cell and rear end is out.
9 inch is apart and cleaned up. Building on the parts to get it hung.
Have a 5.8 set of gears and spool to go in it. And a line on a 327 to power the old girl. Fingers crossed.
wanderinthru
Mid Point Route 66
Shakey
81, 70, 75, 84, 89
K 10, C 30, K 20
Ok. Update.
Trans linkage is made and in.
Brake lines are run to master.
9 inch is fit up. Will take it out to weld it up. Waiting on some parts to do so, it ain't in the way where it is.
The fuel cell cage is finished up. And a bumper is bent, time to get more parts and materials.
This is awesome. Nice work.
wanderinthru
Mid Point Route 66
Shakey
81, 70, 75, 84, 89
K 10, C 30, K 20
Maybe enough parts to get the front end fixed up. Sway bar stuff intend to fab up myself.
And got most of the paint roughed up.
78C10BigTen
pennsylvannia
C10 BIG TEN
Whats the paint scheme gunna be?
wanderinthru
Mid Point Route 66
Shakey
81, 70, 75, 84, 89
K 10, C 30, K 20
The front end parts are on, except the rubber brake lines which should come in today.
Only needed 2 tie rod ends, all else seems good, has new shocks.
Odd I had a 43/64 drill bit for the 5/8 studs. Had to mill flats for the studs to seat flat.
More to do.
wanderinthru
Mid Point Route 66
Shakey
81, 70, 75, 84, 89
K 10, C 30, K 20
Update
Front bumper and little sheet metal nose is fabbed up and on.
Rear bumper and tailgate is built, gutted and on.
Little revamp work on the front hoop. Scored a set of 461's. Looks like brand new valves, springs and retainers. Will get them apart and see. It's cold and windy and time for a nap.
Doug Hampton
