Differences in model years of LS motors
ALL-OF-IT
Nebraska
Adam
323.425844 cubic inches
You'll see dbw in the earlier models with flex fuel. VIN Z
Sent from my SM-G950U using Tapatalk
WFO
Texas Panhandle
Interesting, my 03 engine was cable. It may just be the model. Mine is actually a LM7 from a Tahoe. Actual car engines may be wire.
I bought mine new, but it was late in the year. Maybe they changed mid year.
Termite_Delight
Lanark Ontario Canada
K2500 K2500
350 L33
I've also started looking. I've found several low mileage salvage titled vehicles(salvaged for body issues) for around the $2000 range. There are definitely an early year range and late range for the LS truck engines. I believe the AFM changes came in around 2008 or so. These gave variable valve timing and cylinder shutoff to the 5.3 and 6.0 engines after those years. The LQ4 and LQ9 that everyone tends to swap in are pre-AFM and were made between 1999-2007. The post 2007 6.0L has variable cam phasing and AFM. Those later years would also have a 6l80 or 6L90 6-speed auto rather than the 4L80 that sits behind the LQ4 and LQ9
My 2009 1 ton van has a 6L / 4L80e. Bought it in Missouri & had it shipped north.
Doppleganger
OH-MI: Just like it sounds
Whats the biggest difference between the 5.7 and 6.0? I've heard the 6.0 was a torque monster.
TPISly-C10
Boucherville QC Canada
Sly
C-10 shortbox
LQ4 6.0L
Find a 2004 LQ4 6L for $500 for my swap i all ready got a 4L80E and all the wiring,PCM, ect (GMC Sierra donor)...to made my swap easyer! :)
Pender1
SC
1986|2014
K5|1500
5.3L|5.3L
It was definitely a roll-out change. Not all vehicles changed the same year.
Pender1
SC
1986|2014
K5|1500
5.3L|5.3L
I've got a flex fuel L59 out of a 2002 Tahoe and it's DBC.
4WDKC
Southern Florida
Kacy
My moms 03 Silverado was DBW, had to clean the tb on that damn thing because it was throwing a code.
RoryH19
Rory
R10 Silverado SWB
My 04 Escalade donor is DBW (LQ9 6.0 & 4l65e).
LQ9 has more hp and torq due to piston design.
As mentioned above I would stay with Gen 3 engines to avoid DOD and other fuel mileage features. You can have DOD removed when programming if you find a good deal on your swap.
If you want a 4l80e, I would suggest finding a 3/4 or 1 ton and pull together as a working unit instead of piecing together. This will help avoid any issues during your swap.
This combination will more likely be LQ4 and 4L80e.
As far a DBW goes...I prefer this option. No pedal cables to deal with and it's simple to setup cruise control, just need a 4 wire column switch (83 and up). For the pedal you can use the donor, or if you want the same look as original just use a 90's 6.5 diesel pedal. This is what I've done. Only requires swapping 2 wires on the assembly.
Doppleganger
A guy my buddy works with has an '01 8.1L with Allison trans from a very rotted truck....<100k. Sounds like a beast.
Camar068
Kentucky
10 yrs Air Force
Madhorn
AR-Arkansas
Ken
5.3/NV4500/NP205/4:56 gear/35in tires
read up on www.lt1swap.com He has lots of free information on various parts, years, etc.
dougbert
I used LT1swap for a good share of my swap. A great source of information. Had him flash my PCM as well.
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
A guy i know has one also. If it wasnt so ugly id think about buying it. Heard itll pull down a house but wont pass a gas station.
SkippyDan
