Computerized carb
iservin619
san diego ca
Ivan
GMC sierra
350 small block
Can you put a non-computerized carb on a truck that originally had a computerized carb??
Edelbrock
Earth
Grumba
K5 Blazer
Whats a computerized carb? Do you mean throttle body fuel injection?
Technically yes, you can put a carb on any engine. You could put a carburetor on a diesel engine. It just depends on how many mods you want to do.
fast 99
Spokane, Washington
Feedback carburetor with internal MC solenoid. Think they were only used one or 2 years on trucks. Cars were quite a bit earlier. Actually a decent unit but takes a couple inexpensive tools to set up properly.
Do you truly have a computerized carb or a dual accelerator shot carb? If you have a throttle position sensor on the drivers side and a 2 wire solenoid on the front passenger side top it is a computer controlled carb,if it just has the solenoid top passenger side it is a dual accelerator pump shot. I doubt you have a ccc carb, 1 year only, California only, to the best of my memory. The dual accelerator pump carb is the same as any other quadrajet if it is disconnected.It will cause no issues. Switching to a different quadrajet may cause issues,they are not all set up the same. Different jets,metering rods,air bleeds,spring windup,etc. If it is truly a ccc quadrajet,post back letting us know. Using a non ccc carb on place has its complications,we'll need to walk through the mods.
1983 manual
Cars did have it yes
Yes but trucks it was a 1 year only,California only deal as I remember it.
Fat 454
Australia
C20 Suburban
"Computer Command Control" - producing "harmless CO2".. wow, I wonder how many GM executives today remember this ad ?? Priceless !
SquareRoot
"Space Age Reliability" :laughing1:
starship
