Cigarette lighter
RustyPile
Left on own accord
Elkhart, TX
Nick
1983 GMC
350 SBC
Again...yes, you do need a ground and a power source for the cigarette lighter aka power terminal to work...its how dc power works.
smoothandlow, if you're disagreeing with me on the need for a ground wire, the ash tray housing is bonded to the dash via the pivot pins and springs. The dash is bonded to the body.. And lastly, the body is connected to the battery negative via ground wires and the negative battery cable.. So no - no ground wire is needed.. If your post was made to emphasize my post, then disregard this post...
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
The lighter pulls more amps than a cell phone charger . Plugging in a carcharger under normal circumstances won't blow the fuse unless themcharger itself is shorted out internally (I had this happen in my wifes car...popped fuse...ended up the charger was junk).
Now, if you use the cigarette lighter power outlet to charge say a inverter, then yes, it will get overloaded
Yes...I was emphasizing your post regarding a ground on a 12v dc circuit.
I agree, long term use for a simple phone charger : no problemo.
But using it long term for something like a 400w power inverter: es no bueno.
Iowan
Loud and Proud American!
Iowa
Calvin
K1500
350 crate
So I get in my truck and plug in my charger, phones still not charging, so I go to pull it out and find out its connected to nothing :emotions34::laughing1::pp:
Pineywoodsbow
Jason
I'm done.........
ring terminal is all I had at the time. what is a female bullet connector?
btw it is still blowing the fuse when I plug in the cigarette lighter....
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
What happens when you plug your charger in to it? Could be a faulty lighter button.
smoothandlow84
Steve
In the electrical world...
male bullet connector : penis
female bullet connector : ******
and don't get me started on "butt splice connectors"....
smoothandlow84
Steve
Lmao.....
Did you see the vid of the Git Down chevy show that I posted earlier? :)
jdc72cutlass
