- Aug 29, 2010
- OKC, OK
- HotRod
- 85 K20 LWB
- Silverado
- 454 - Turbo 400 - 3.73
I call ******** on it except for a few very freak happenings due to odds and numbers. I plan to do a dissection and write up on the charcoal canister from the '89.
I'd imagine some might even wonder WTF is it for?!?!
It's for sealed fuel or gas tanks. Back in the day, you could buy VENTED gas caps, so as fuel sloshes around and creates vapor, or just getting warm from ambient air temp, fuel vapor is created expands in the tank and would escape from the vented gas cap.
So now, sealed gas caps came about that allow the gas tank to become somewhat pressurizd. The pressure pushed the vapor to the charcoal canistar where it was stored. Then when the right chain of events happen, like the vechile warmed up, or when off idle, the intake or vacuum from the intake and carb would draw the stored vapors from the Charcoal Canister and run them thru the motor to burn off the vapors that are harnful to the ozone and omit HC's into the air.
