Carb or tbi
4WDKC
Southern Florida
Kacy
A and B lol, pretty straightforward.
Thats great to get a code if it sets one, but these systems dont have self tests so you may get a code that says its a bad MAP, when in actuality its a bad o2 sensor. last truck I had didnt set a code, wouldn't start without starting fluid, no fuel spray while cranking, had high idle, no vacuum leak, caused transmission to not want to shift, ran rich as hell. Fuel pump was good, ICM was good, relay was good. Can't solve that with a paper clip.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Wanna bet? I can short the ECM with one and further my reasoning to tear it out.lol just not a fan of OEM TBI. I didn't like CPI once I converted it to MPI in my 99 Tahoe I loved that thing.
4WDKC
Southern Florida
Kacy
point was you cant see the info the ecm is getting that caused it to do all that trying to compensate for a bad TPS
I agree with that. The paperclip method has both led me to solve a problem and led me nowhere. I will say that the serial data scan tool that some of us have made for a few bucks really steps it up a notch. You can see everything the ECM sees and decide what doesn't look right for yourself.
Spoonbill45
Independence,mo
Dustin
C10 Silverado
I converted my '87 from TBI to a carb and the swap was straight forward and easy. Finding the right deals on CL or ebay can save some $$. I spent a total of $150. Ask yourself what your goal is for your ride and then go from there. Do what is in your budget. If it aint broke dont fix it. I opted for the carb swap because I plan on going up in HP and my truck is not a DD so reliability is not my main concern anymore. But that is my $0.02
Spoonbill45
Independence,mo
Dustin
C10 Silverado
I too have a 87 tbi 305 700r4 and I want to switch to a carb setup. I know nothing about efi and don't want to know. I thought it would cost about $1000 but you said you were able to do it for$150. What all did you get and from where? Thanks
4WDKC
Southern Florida
Kacy
You will need a carb intake, 600 cfm carb, 75-85 ish standard hei dist., a regulator the keeps fuel pressure at 6 psi max so you don't flood the carb. If you know what you are doing and looking at you can buy used, if not find someone to help you or buy new so you dont get ripped off.
Spoonbill45
Independence,mo
Dustin
C10 Silverado
Thanks for the info. I always get everything from jegs and summit. Aftermarket is so much better than factory. I will use edelbrock for everything I can and then for the stuff that edelbrock doesn't have I will look it up and see what manufacturers there are and make my decision my decision. I figure about $1000
RangRayy
Kansas City, Missouri
ryan
r10
I bought an Edlebrock intake used (2104) off Craigslist for $45. They even shipped it because it wasnt local. Bought a used Edlebrock 1406 carb off ebay for $50 and my brother works at O'Reilly's so he gave me a discount on a new electric fuel pump that run normally $43 and only push 3-4psi max so no regulator needed. I also am using a fuel cell instead of my stock tanks. He also threw in some gaskets with the discount. Plus he already had a HEI laying around he wasnt using so it was free. I also had to fab up a bracket for my kick down cable for my TH350.
I would look for used parts, alot cheaper and with some research can be had. Although buying new is nice it can get expensive which some will say is not necessary and not worth it to do the swap.
78silverado
