Limey
- Jan 30, 2014
- Lawrenceville GA
- Paul
- K10
Hi you'll,
I have a 305 stock engine 131k original milea in my '85 K10. I've had it for 10 years, never had a problem. 3 weeks ago the engine stalled while I was running about. Kinda like running out of gas. I let the engine cool, and limped home. No spark.. I Replaced the ignition module, and she fired right up. Thought I'd fixed it. The issue is when I load the engine it begins to misfire backfire, and run like crud. I will barely make it up my driveway. Timing is good. I replaced the spark plug wires (MSD), Still the same. Spark plugs are old, but not fouled. She was running fine, until I got into the distributor. What should I do next?
Thanks in advance
Limey
Thanks in advance
Limey
