Can someone tell me the length of the z bar/bell crank for an 83 K10, manual clutch?
JoeyC75
Hiawassee, GA
Joey
Can someone tell me the length of the z bar on an 83 K10, sm465, manual clutch. Mine seems to be too short.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
Pictures
JoeyC75
Hiawassee, GA
Joey
I'll grab some after work
i wasnt aware of there being different length z bar bell crank thingies. lol
Heres a poor picture of mine, 1980
Heres a picture of one out of a 1977 K25
JoeyC75
Hiawassee, GA
Joey
I think my frame may be slightly bent. When you depress the clutch pedal, the bar is coming off of the frame side pivot ball, and the adjustment rod at the clutch fork is at a pretty good angle.
JoeyC75
Hiawassee, GA
Joey
I also think my truck may have started life as a two wheel drive, and possibly an automatic (at least the body). I'm not sure if it is even on the factory 1983 frame. I get the feeling that it is made up of numerous trucks and parts that were cobbled together. If you can, post a picture of your z bar with a tape measure beside it, so I can compare the overall length, and mounting points for the linkage connections. Someone modified the frame side pivot ball to extend it, before I bought the truck, and the weld on it broke, disabling my clutch. That's when I discovered the z bar wasn't long enough, or the frame side is bent outward. Thanks in advance.
it may not be a frame issue but they may have broken the stud , bad power train mounts can twist and put them at extreme angles.
heres what the frame bracket looks like
Also do they have the stud on the engine block or the bellhousing?
Ignore the circle in the next pic
Mine is kinda twisty because of bad mounts, so dont take mine as gospel, but heres just more pictures to help possibly
Fitz
Washington, OK.
Don
K-10
454/F60/465/205/FF14
Bad transmission or motor mount (on the drivers side) will allow the engine to "raise up" when accelerating. That results in the the Z bar being pulled of of the pivot ball. When that happens, you will lose the clutch operation. I installed new motor mounts, along with both of the new pivot balls. One that mounts on the engine, or bellhousing. And the one that mounts on the frame. Got everything that I needed new at Classic Parts out of Kansa City, MO.
JoeyC75
Hiawassee, GA
Joey
I ordered new everything linkage wise, going to install everything, and see what it looks like. I will check my engine and transmission mounts also. I appreciate all the input.
I dont remember what this is specifically for.. its shorter than my zbar i have shown you, but its a good picture of the components.
thatgermanguy
