Can it be saved
Michael Benardo
Vallejo, California
Michael
C 25
292 Cubes
Nope...No way is it ever going to work again after sittin' for 10 years. Way TOO long for any vehicle. So just have it shipped over here to me.... aka...."Mike's GM Square Hospice House" and I will gently help it move on to the next life!! What are friends for...Right! lol:party52:
This web-site is dedicated to keeping Square Bodies on the road, not to get them scrapped and the metal sent to Japan.
Salty Crusty
Gary
c1500
Short squirt of WD-40 in each bore. Doesn't take much, capillary action will get it pretty much all the way around the bore.
I would mark and pull the distributor and re-prime it so you don't have dry lifters on dry cam lobes.
Swap the gas and fire it up!
If you'll watch some of the RoadKill shows, they've fired up some engines that have sat for twice this long with no issues.
Paladin
"Teufelshunde"
Wichita Falls, Texas
C30 Silverado Crew Cab Dually
Damn, lighten up dude, my post was meant in jest. Maybe Santa will bring you a sense of humor for Christmas!
RoryH19
Rory
R10 Silverado SWB
I did the same with PB blaster. pulled the plugs, sprayed each piston and let if sit for a week. sprayed a few times during the week. engine would then turn. put a starter, fuel pump and used a plastic gas tank for fuel. Put new plugs in too and cleaned the disco and rotor. After some cranking it fired up. you can't believe all of the debris that came out of the exhaust. it sat in a field for 10+ years.
Michael Benardo
Vallejo, California
Michael
C 25
292 Cubes
You should see what has happened here in California. There are almost ZERO American cars left on the road, so yes, I am sensitive about that.
gotyourgoat
NRV Virginia
gotyourgoat
smokin' 305
Don't listen to scrappers. If your engine is free, yes you can put it back on the road. You might have to rebuild the brake system, and your pinion shaft and axle shaft seals might go, but your engine should be fine.
You apparently don't know where you are or what you are talking about.
RecklessWOT
New Hampshire
Kevin
V10 Suburban Silverado
Dude, it was obviously a joke. Like the truck is most likely fine and they are jokingly saying "oh, no you should just send it to me"
WebMonkey
Missouri Ozarks
sorry for dragging the post further off topic;
the reason so many members said 'scrap and send it to ME' is that USED to be a very common phrase.
it was ALWAYS intended to the person posing the question, that whatever they had, it was worth the responder's effort/money to have it and love on it.
if you venture to any other forum on any other topic, you WILL encounter this response again.
to translate into another verbage:
'sounds like you've got something i'd put time/effort into in a heartbeat'.
finally :), this forum has been around awhile. you might try 'reading the room' before you take offense at 49 other states and several other countries.
back to the OP:
shoot, sounds like way more trouble than it's worth. send it to me and i'll get that eyesore out of your sight!
Michael Benardo
Vallejo, California
Michael
C 25
292 Cubes
back to the OP:
Only one said it.
BrianBaca
