Raider L
- Sep 1, 2020
- Shreveport, LA
- William
- C10
@jasonconaway,
I have a Lunadi in my trucks 350 very close to the Voodoo. You'll like it, it has excellent across the band power and it has a bit of a lope. It's a good general use performance cam and the 1800 to 6200 rpm is perfect. You won't need big heads, that will save you money but do use a good flowing head just not race heads. These days people are using the high lift relatively short duration cams and get good horse power/torque band cross at between 5500 and 6500 rpm. It ain't a head snapper like some of the Comp. Cams are and for a good all around hydraulic lift cam I think you'll like it. Put on a good set of headers and if you want put a TCI Saturday Night Special 2000 stall torque converter or one up to 2500 in your trans and you'll have a lot of fun!!
