Bvllsh!t on craigslist.
Yep, even the 1 tons will bend behind the cab. This is why when GMT800 came out, the frames were hydroformed I believe it's called. Actually very strong even though it appears to be 2 pieces. It actually sorta is.
And our frames are so flexy, they really can't be bent, lol.
I thought so. Here's the Wiki on GMT800 frames. They are actually 3 piece frames. Good luck getting the pieces apart though. I"m sure it can be done though.
The GMT800 introduced a three section frame system, which could be mixed and matched depending on the wheelbase, GVWR, and body type fitted to the platform, rather than a single piece long frame. The front section was hydroformed. The middle and rear sections were roll formed or stamped, depending on application. This gives greater flexibility to the platform. A total of four front modules, seven midsections, and four rear sections were created to mix and match for nearly 40 different truck configurations.
J Knight
Baytown TX
82 Chevy
350ci
J Knight
Baytown TX
82 Chevy
350ci
OOOhhhhh, so all you have to do is put the words "Street Couple" on the side and it becomes one. I get it now.
78silverado
