Burnouts with a NP203 full time 4wd?
Octane
Atlanta
Eddie
I like how theres some here that just aint got the guts to to push the skinny and deal with the consequences
Like @82sbshortbed said, its a big block, put that mf to the floor
pretty bad when the 67 year old man will do burnouts, not to mention im sure idahovette will too, and we all know joe has in his blown c10....
Excuses :321:
Heck yeah,deal with the results...at 62 yo I'll let 'er rip...or rip out!
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Idc what blows up, if something dies, it lets me know the weak point..
Just yesterday i was romping around in my s10 trail truck in prep for the forest trail riding at uwharrie national park this weekend.
I smash the gas , tires spin, pedal gets stuck under the floor mat, i throw her in what i thought was neutral.... which was actually reverse, tires lock down and spin backwards .
I said to myself eyyyyyyyyy, that job i did on that 4L60e isnt so bad after all.
Thats on cut and grooved 39.5x15x16 boggers.
SquareRoot
I'm more impressed you have boggers behind a 4.3. lol
Vbb199
Salisbury NC
Vince
With the gmt400 np241 i swapped, and the 4.10s, accompanied by the low 1st gear of the 4L60e, it dont do too bad.
I estimated roughly 230-250 hp on the 4.3 when it rode on the roads based off of compression, bore, and chip programming. Its not a screaming eagle, but its got decent low end torque
Its a vortec 4.3, but prior to coil packs... uses a dizzy, and CMFI
82sbshortbed
Fuckemall!!
SE Texas
Doug
1500 shortbed, 1500 longbed
:lol:
That's gay. This country's had a good run but, I'm afraid we are going down a slippery slope that we won't come back from.
Vbb199
Salisbury NC
Vince
Hey, be careful, lol.
I got sent home from work for a week last year for callin a guy a *****!
He was, but....
:lol:
When i know we've finally reached rock bottom is when weld shops and machine shops start sending you home for saying "mean words"
Octane
Atlanta
Eddie
Our maintenance shop had to take down a poster of a Miss Makita or something like that,per our h.r. dept that just happened to stick her nose in the door.I bet if a poster of two tranny **** were on the wall she wouldn't have minded.
74Blaze
Nashville, IN
Gerald
K5/Blazer
I am new to the forum and don't have privileges to post a new thread, so I'm asking my questions a reply to this thread.
I've owned my '74 K5 since 2007. It had an NP203 with the conversion kit when I bought it. The transfer case took a dump earlier this year. I replaced it with a used non-converted (still full-time) case. When I drive it at slow speeds it feels kind of like a part-time case in 4WD. That is, I feel it grab a bit when turning (a little jerky). Is this normal for a non-converted NP203?
77 K20
Montana
K20 5" lift
HT383 fuel injected
No. It should be very smooth for doing tight turns. Are you sure you are not in the 4 HI LOC position?
If your transfer case lever is all the way forward (LO LOC) or all the way back towards the seats that is HI LOC. In those positions the transfer case is locking the front and rear drivelines together (just like a part-time case). Move the transfer case one click forward and it is just in HI. This unlocks the transfer case and allows for different driveline speeds front vs rear.
In case you don't know the shift pattern:
LO LOC
LO
Neutral
HI
HI LOC
Have you tried any burnouts? :hahano:
74Blaze
Nashville, IN
Gerald
K5/Blazer
Yes, I still have the locking hubs. So to check that, I turned them to the unlock position and put it in gear. The Blazer wouldn't move as expected.
I don't have the original shifter. I had J&B build me a custom twin-stick cable shifter. It has very positive shift positions.
Not yet. Still feeling old girl out after the major work to replace/fix the damage when the old transfer case blew.
77 K20
Montana
K20 5" lift
HT383 fuel injected
Sounds like the transfer case is working then if it doesn't move when the hubs are unlocked.
So do you feel it "grabbing" thru the steering wheel? Or? And this is at parking lot speeds?
74Blaze
Nashville, IN
Gerald
K5/Blazer
Only at parking lot speeds. At anything faster it feels fine. Not so much through the steering wheel, just feels like it binds a bit.
kobedemello
