Ya ok good catch Jerry. I circled in red the area that really shows that something is up.
But if you notice from those 2 pictures, there seems to be about an 1" difference in the gap between the frame and the rad support. This is what is giving you greif with your bumper not lining up.
the frame being tweaked may be why your suspension seems to be so uneven from side to side.
The point Im making is that even if you got your bumper to line up nice and parallel to the ground it would still severely be crooked compared to your body because of those body bushings! If you replaced the body bushings then the bumper would line up with the body despite the frame being tweaked, but would probably be a little askew in relation to the ground.
Obviously you will never get it straight in realation to both until you get the suspension to even out.
Also I wouldn't doubt that the frame is still parallel to the ground but rather tweaked to the side. This is why I say that the body bushings are why your bumper wont line up to your body. Even if you fixed your frame the bumper would still be crooked to the body!
I don't think that frame horn is bent that much up or down compared to the other side. Maybe im wrong ???
You would have to get a nice flat piece of concrete and then use large jack stands underneath the frame rails to support the truck off the ground and then start measuring from the frame to the ground side to side front to back, in order to see if the frame is tweaked in relation to being parallel to the ground.
